Where exactly is the air filter box located for a 2.5 TDI A6, manufactured in 1996?
saxi
Post13-06-2002, 21:48    Subject: Where exactly is the air filter box located for a 2.5 TDI A6, manufactured in 1996? Quote
hmm, sounds like it might be a bit silly... but can someone tell me where the air filter is located in my A6?
olli
Karma: +46 / -0   Thank you, like it!
Post13-06-2002, 22:20    Subject: Where exactly is the air filter box located for a 2.5 TDI A6, manufactured in 1996? Quote
should be located on the left, when you are standing in front of the engine compartment.
To remove the cover, you need to remove a plastic part that directs the air intake from the radiator grille to the air filter.
Olli
wolle
Post14-06-2002, 10:52    Subject: Where exactly is the air filter box located for a 2.5 TDI A6, manufactured in 1996? Quote
Hi Saxi,
Olli is right. The air filter is located, when viewed in the direction of travel, on the right side of the engine compartment, essentially between the headlights and the shock absorber. The plastic part that Olli mentioned can simply be removed. Then there is also an air hose that is attached with a quick-release clamp. You need to remove this hose. Don't worry... it's completely harmless. Furthermore, the MAF (mass airflow sensor) with a power connection and an electrically controlled valve are located in the air filter housing. You also need to remove these two connectors. (Press and pull) You can also easily distinguish the two connectors. Finally, remove the two vacuum hoses at the top of the valve mentioned above. But only the two upper ones. If you have now removed the 4 clips on the air filter housing cover, you can remove the cover.
ENJOY!
Greetings
saxi
Post14-06-2002, 16:33    Subject: Where exactly is the air filter box located for a 2.5 TDI A6, manufactured in 1996? Quote
thanks everyone...I'll take a look at it right away-)))
Hi Saxi,
ENJOY!
Greetings
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Do windows open on their own? General Tips
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN: Location of the sensor plug. Diesel Engine Technology
No new posts Where is the differential pressure sensor located? Diesel Engine Technology
No new posts VW Active System: How it Works & Benefits Transmission, Chassis, Body & Interior
No new posts How exactly does the ESP work? Diesel Engine Technology
