Loose Steering: Troubleshooting & Fixes
Go to page: 1, 2  Next
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Juergen
Post28-03-2004, 13:42    Subject: Loose Steering: Troubleshooting & Fixes Quote
Hello everyone,
I've already tried using the search function, but I haven't found a solution to my specific problem.
Vehicle: Volkswagen Golf IV; Year of manufacture: 03/2003; Mileage: 18,000 km.
Symptom:
The steering has noticeable and audible play, which seems to be getting worse.
However, there is no visible or noticeable play in the tie rod ends.
However, you can feel the play if you touch the left tie rod end (only on the left side) and simultaneously move the steering wheel back and forth quickly.
The clicking sound seems to be coming from the steering gear.
Does anyone have any idea what this could be? Even though I still have the manufacturer's warranty, I would like to minimize the time spent at the workshop.
Jürgen.
Translated on 12-08-2026, 9:10.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post28-03-2004, 14:14    Subject: Loose Steering: Troubleshooting & Fixes Quote
hello Do you have a rack and pinion steering gearbox (long) or a ball bearing recirculating system (compact with steering shaft linkage)? icon_question.gif icon_arrow.gif
B.Eng (FH) u. KFZ Meister
Translated on 12-08-2026, 9:11.
Julian
Post28-03-2004, 16:08    Subject: Loose Steering: Troubleshooting & Fixes Quote
The Golf 4 exclusively uses rack and pinion steering.
On the steering gear housing (when viewed from below and behind, only visible on a lift), there is a special screw located on the driver's side that can be used to adjust the play.
However, this is specialized workshop work, and you shouldn't try to tinker with it yourself, especially since you still have a warranty.
Furthermore, it should be checked whether the front stabilizer mounts are still intact and that the stabilizers are not making contact with anything. This is a common issue on Golf 4 models.
Translated on 12-08-2026, 9:12.
Juergen
Post29-03-2004, 8:51    Subject: Loose Steering: Troubleshooting & Fixes Quote
Hi Julian,
Die Einstellschraube am Lenkgetriebe habe ich gesehen, man kommt aber meiner Ansicht nach nicht ohne grössere Abbauarbeiten ran. Folge: langer Werkstattaufenthalt! Correct?
The only thing I can't understand is why this is felt on the left tie rod alone and not on both.
Greetings and thank you very much.
Jürgen.
Translated on 12-08-2026, 9:13.
christians
Post29-03-2004, 13:17    Subject: Loose Steering: Troubleshooting & Fixes Quote
How about an inner tie rod end?
Gruß Christian
Translated on 12-08-2026, 9:14.
Juergen
Post29-03-2004, 14:09    Subject: Loose Steering: Troubleshooting & Fixes Quote
I had already thought about that.
According to the do-it-yourself instructions, the steering gear must be removed in order to replace the tie rod.
Are there any other methods besides steering wheel shaking to help narrow down the cause of the problem?
Greetings.
Jürgen.
Andy
Post29-03-2004, 14:16    Subject: Loose Steering: Troubleshooting & Fixes Quote
Are there any other methods besides steering wheel vibrations to help narrow down the cause of the problem?
'Yes, they exist. At the TÜV (German technical inspection authority), there's always a pneumatic shaker available. If you ask the inspector nicely, you might even be allowed to perform an intensive check using it.'
'Tip:'
Whenever I suspect instability in the front axle, I usually take it to an ADAC inspection, which is free of charge. After the inspection, there's always a short period where they can test the front axle on a shaker machine.
Andy.
Translated on 12-08-2026, 9:16.
Julian
Post29-03-2004, 16:16    Subject: Loose Steering: Troubleshooting & Fixes Quote
Hi Julian,
Well, if you consider jacking up the car and removing the underbody panel as a lot of work... it's actually quite quick to do.
The inner tie rod ends never break; they are either defective from the beginning or last for the entire lifespan of a car.
The outer layers degrade relatively quickly if the rubber coating is damaged, icon_wink.gif.
Translated on 12-08-2026, 9:17.
felix
Avatar-felix
Post29-03-2004, 17:22    Subject: Loose Steering: Troubleshooting & Fixes Quote
@JulianViewing profile: Julian
Both of the internal ones failed for me at around 30,000 km.
@JuergenViewing profile: Juergen
I just saw your manufacturing year. That should still be covered by the warranty; it worked for me too.
Gruß Felix
E91 330d, 1/2009
Translated on 12-08-2026, 9:18.
Albrecht
Post29-03-2004, 22:12    Subject: Loose Steering: Troubleshooting & Fixes Quote
Hello Jürgen,
In my case, the ball joints also showed signs of wear at 94,000 km (Passat 35i).
"When you turn the steering wheel completely, you can feel the joint through the boot on the steering gear housing. I replaced it without removing the steering gear (according to the repair manual, this is also necessary for the Passat 35i)."
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 12-08-2026, 9:20.
Juergen
Post30-03-2004, 11:20    Subject: Loose Steering: Troubleshooting & Fixes Quote
Hello everyone,
I visited the friendly VAG workshop today because of this issue.
The KD champion stated that the cause of the play and rattling was 'rear lower control arm bushings that were too soft.'
On Thursday, they will be replaced under warranty; I will report back then.
Greetings.
Jürgen.
Translated on 12-08-2026, 9:21.
Gremlin
Post30-03-2004, 14:57    Subject: Loose Steering: Troubleshooting & Fixes Quote
After 25,000 kilometers, the two ball joints on my steering linkage were worn out.
The steering had more play in it than the one in my great-grandfather's old car (tm) after 14 years and 195,000 kilometers...
CU Gremlin.
Translated on 12-08-2026, 9:22.
Julian
Post30-03-2004, 17:58    Subject: Loose Steering: Troubleshooting & Fixes Quote
In my case, after 25,000 km, the two ball joints of the steering linkage were worn out.
Do you know where something like that comes from? (No joke): It's from steering with one hand! The steering system is designed for the driver to use two hands, which means only a rotational force is applied to the steering shaft. When steering with one hand, there's also a bending moment added, and it seems your steering system may be slightly undersized to handle that... icon_biggrin.gif
Translated on 12-08-2026, 9:23.
christians
Post30-03-2004, 21:21    Subject: Loose Steering: Troubleshooting & Fixes Quote
No, no, how are you supposed to transmit a bending moment across the cross joints?
Gruß Christian
Translated on 12-08-2026, 9:24.
Julian
Post30-03-2004, 21:26    Subject: Loose Steering: Troubleshooting & Fixes Quote
Well, not about those, but about the bearings that then wear out faster... please don't ignore my smileys! icon_wink.gif
Translated on 12-08-2026, 9:25.
Gremlin
Post30-03-2004, 22:43    Subject: Loose Steering: Troubleshooting & Fixes Quote
Do you know where something like that comes from? (No joke): It's from steering with one hand! The steering system is designed for the driver to use both hands, which means only a rotational force is applied to the steering shaft. When steering with one hand, there's also a bending moment added, and it seems your steering system may have been slightly undersized to handle that... icon_biggrin.gif
CU Gremlin.
Translated on 12-08-2026, 9:26.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Rear Engine Mount for VW T6 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Problems: Side Slip & Handling Issues? Transmission, Chassis, Body & Interior
No new posts Performance loss and no one knows what to do On-Board Diagnostics (OBD)
No new posts Fehlercode 00575 u. 17978, wer weiß rat? On-Board Diagnostics (OBD)
No new posts AHU Startup Issues: Troubleshooting & Help Diesel Engine Technology
