Audi B4: Retrofit Climate Control System.
Kissenknicker
Post23-03-2004, 21:41    Subject: Audi B4: Retrofit Climate Control System. Quote
I want to convert the manual climate control in my B4 to automatic climate control. I already have the heater box with all the necessary actuators, and the wiring harness for the control unit. Besides the control unit itself, what else do I need for the conversion?
I am grateful for any advice or help. Perhaps someone has already done something similar before.
Vehicle:
Audi 80 B4.
1Z 90hp TDI
Bj.: 12/93
(Translation: Year of manufacture: 12/93)
170,000 km
Translated on 30-09-2026, 10:16.
mersente
Post23-03-2004, 21:45    Subject: Audi B4: Retrofit Climate Control System. Quote
Hello, you still need piping with pressure sensors, a compressor, a condenser, and a dryer.
Translated on 30-09-2026, 10:17.
Kissenknicker
Post23-03-2004, 21:58    Subject: Audi B4: Retrofit Climate Control System. Quote
Hello, you still need pipes with pressure sensors, a compressor, a condenser, and a dryer.
Yes, that's true, but shouldn't those features already be included in the standard air conditioning system? Or are they different with the automatic climate control?
Do climate control motors operate with negative pressure or positive pressure?
mersente
Post23-03-2004, 22:25    Subject: Audi B4: Retrofit Climate Control System. Quote
Oh, I see, you already have a manual climate control system, so you have everything you need.
Translated on 30-09-2026, 10:18.
Kissenknicker
Post24-03-2004, 20:39    Subject: Audi B4: Retrofit Climate Control System. Quote
I only have one more question: The control system also needs to be powered by a voltage.
Do you need a second wiring harness for this, one that connects to the board's electronics?
Does the VAG interface work for reading error codes?
Best regards, Kissenknicker.
mersente
Post24-03-2004, 21:08    Subject: Audi B4: Retrofit Climate Control System. Quote
It's probably not possible to read the data from the old climate control system.
It's best to get a wiring diagram so you can run the power cables yourself. Also, you'll be able to see what other components you might need (relays, temperature sensors, etc.).
Translated on 30-09-2026, 10:19.
Kissenknicker
Post24-03-2004, 21:26    Subject: Audi B4: Retrofit Climate Control System. Quote
Where can I find such a schematic diagram? Is there any information about it available online? Perhaps even here in this forum?
mersente
Post24-03-2004, 21:28    Subject: Audi B4: Retrofit Climate Control System. Quote
I'll take a look tomorrow.
Translated on 30-09-2026, 10:20.
mersente
Post25-03-2004, 21:57    Subject: Audi B4: Retrofit Climate Control System. Quote
Hello, I sent you the circuit diagram via email (it's about 3MB - you wanted to be able to see something on it), and I hope it helps you.
Kissenknicker
Post26-03-2004, 21:51    Subject: Audi B4: Retrofit Climate Control System. Quote
Hello, yes, I received it today. It looks pretty good.
Thank you very much!
mersente
Post26-03-2004, 22:16    Subject: Audi B4: Retrofit Climate Control System. Quote
No problem, just let me know if you have any issues.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Parking Assist Audi A4 (B5) Retrofit Transmission, Chassis, Body & Interior
No new posts Audi A4 B5 ASR/EDS Retrofit: Installation Guide Transmission, Chassis, Body & Interior
No new posts Audi A4 8E: Retrofit GRA & Onboard Computer On-Board Diagnostics (OBD)
No new posts Retrofitting hands-free system for Audi A4 8K, year 2008 Electrical Systems, Vehicle Electronics, Multimedia
