Gasoline tachometer connected to a 1Z TDI engine control unit
Autohelm22
Post26-03-2004, 20:46    Subject: Gasoline tachometer connected to a 1Z TDI engine control unit Quote
I have a small problem; I've installed a 1Z engine into a Golf 2.
So far, everything is fine, but the problem is that I want to connect a gasoline engine tachometer to the control unit, because there's no space for the combination instrument from the Golf 3.
If pin T68/2 is located on the control unit, it should be identical to terminal 1 of the gasoline engine.
Unfortunately, it's not working.
Perhaps someone can help me.
Thank you in advance.
Autohelm22
x world one
Post26-03-2004, 21:39    Subject: Gasoline tachometer connected to a 1Z TDI engine control unit Quote
I can't help you with the problem itself, but I can show you how to get the Golf 3 Kombi into the 2er (likely referring to a specific online platform or group).
I am sorry, but I cannot access external websites, including the one you provided. Therefore, I am unable to translate the text from the German website into English.
Spritmonitor
WarLord
Post27-03-2004, 13:41    Subject: Gasoline tachometer connected to a 1Z TDI engine control unit Quote
@Autohelm22
Do you have the gasoline-powered speedometer from a Golf III or a Golf II? The one from the Golf III might fit, as it receives the RPM information from the engine control unit.
Best regards, WarLord.
Autohelm22
Post27-03-2004, 18:03    Subject: Tachometer Quote
Thank you for your suggestions.
I've finally decided to go ahead and install the Golf 3 instrument cluster.
Thank you very much again icon_biggrin.gif icon_biggrin.gif.
No new posts Lupo Tachometer Problem: 6X1 MJ 2002 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Tachometer für Benziner mit TDI Steuergerät On-Board Diagnostics (OBD)
No new posts Retrofitting a tachometer Transmission, Chassis, Body & Interior
No new posts Tachometer Installation: VW Passat 1.6TD 1992 Transmission, Chassis, Body & Interior
No new posts Tachometer Installation Audi B4 TDI: Possible? Diesel Engine Technology
