How is the factory-installed AHK (trailer hitch) wired?
WarLord
Post28-03-2004, 12:54    Subject: How is the factory-installed AHK (trailer hitch) wired? Quote
Okay, as the title suggests, my question is: Do the cables run separately to the front, or are they just attached to the brake lines etc., like the aftermarket kits?
Best regards, WarLord.
Translated on 21-07-2026, 18:44.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post28-03-2004, 13:10    Subject: How is the factory-installed AHK (trailer hitch) wired? Quote
Okay, so it seems that in older cars up to the year 2001, only the wiring for the turn signal indicator light runs to the front, and everything else is tapped into from the rear. At least, that's how it works with Audis.
However, starting in 2002, you will need to install a complete wiring harness for the CAN bus.
And you would have to recode the trailer module in the combination instrument, etc. However, you can forget about doing that with VAGcom; you'll need to go directly to a workshop. icon_biggrin.gif
B.Eng (FH) u. KFZ Meister
Translated on 21-07-2026, 18:45.
WarLord
Post28-03-2004, 14:57    Subject: How is the factory-installed AHK (trailer hitch) wired? Quote
Hm, ich hab nämlich nen Passat 3B von 2000, welcher CAN Bus hat. Der hat ne AHK von Westfalia (13 polig) und da ist die Blackbox im Kofferraum. Ich hatte noch keinen Anhänger dran, aber es geht anscheind kein Kabel nach vorne (es wird an die vorhandenen Kabel, welche zu den Lichtern gehen angeklemmt). Von dem her bin ich auch nicht davon überzeugt, dass die Fahrtrichtungsleuchten des Anhängers angezeigt wird (in der MFA). WIs there a way to check if the MFA is correctly configured?
Translated on 21-07-2026, 18:46.
Post28-03-2004, 15:03    Subject: How is the factory-installed AHK (trailer hitch) wired? Quote
If it's not original, it will have a so-called "check control" (or something similar). If the turn signal bulb on the hanger is broken, the entire car will blink faster, just like with a defective vehicle bulb. I think it would be difficult to add a combination instrument warning light later. If anyone has an idea about this, I'm also interested.
Translated on 21-07-2026, 18:47.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post28-03-2004, 18:01    Subject: How is the factory-installed AHK (trailer hitch) wired? Quote
The CAN bus your Passat has might be a completely different one.
Just check if your vehicle has a trailer module installed.
It should be installed in the same way as on an A4, specifically on the rear left side. However, it requires a complete replacement of the side panels! icon_lol.gif
Isn't that great? icon_twisted.gif Probably it won't be long before the sun visor also becomes diagnostic. }
Translated on 21-07-2026, 18:48.
No new posts HB4 Blind from Factory: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Outdoor Temperature Sensor: Best Placement Location Diesel Engine Technology
This topic is locked, you cannot edit or reply. Wheel Alignment Today: New Tires Installed Transmission, Chassis, Body & Interior
No new posts Vintage Valve Adjustment: Factory Secrets Diesel Engine Technology
