Login Code for Comfort Control Unit in Skoda Octavia
rembacher
Post29-03-2004, 19:32    Subject: Login Code for Comfort Control Unit in Skoda Octavia Quote
Hello everyone!
I bought a new container for the FFB for my Octavia. Unfortunately, the new FFB cannot be added as an additional FFB; instead, only one FFB is activated during the pairing process (sometimes one, sometimes the other FFB). I purchased a VAG-COM with a data cable, as I thought that more than 4 keys could be programmed. However, the VAG-COM only shows one key in the comfort control unit. If I increase the value to 2 and want to test or save it, the value always remains 1.
I assume that I first need to perform a login in the comfort control unit and then add the new key.
Unfortunately, I don't know the login code (I can't find any information about it in my repair manual either).
Can anyone please help?
Thank you.
LG
rembacher
mersente
Post29-03-2004, 19:41    Subject: Login Code for Comfort Control Unit in Skoda Octavia Quote
Hello, do you see here:
/viewtopic.php?t=3576
Danilo100
Post30-03-2004, 17:27    Subject: Login Code for Comfort Control Unit in Skoda Octavia Quote
I also followed the above link. In Michael II's instructions, I'm missing the use of the 7-digit PIN code when programming the key. Is this necessary, or am I confusing something?
Danilo
Back to top Profile PM Email
Thomas Falke
Post30-03-2004, 19:06    Subject: Login Code for Comfort Control Unit in Skoda Octavia Quote
Hello, he only wants to pair the remote control. He doesn't want to program the transponder.
rembacher
Post31-03-2004, 7:06    Subject: Key learning Quote
Hello!
I tried the learning process according to Michael II's instructions using the VAG-COM and KKL cable.
I selected the "Adjust" function, channel 00, and "Save" in the diagnostic system. When I then switch to channel 01, a key is still displayed in green text. If I enter "00002" in the "New Value" field and then select "Test", the key "1" is still displayed. When entering "0002" and saving again, a security prompt will appear asking if the value "01" should be saved. --> The control unit rejects my input of "00002" (or "2") and instead always sets the value to 1.
Do I perhaps need to log in (Function 11) to the control unit first?
If so, my repair manual does not contain a login code, and I do not have the original Skoda manual.
Another possibility is that the control unit (the EEPROM) is faulty - or?
In Function 08, Channel 03, when the FFB is activated, the value 4 is displayed in the rightmost field (4 keys are stored) --> Deleting the storage with function 10 (Adjustment) is not being performed.
Maybe you could help me further.
Thank you.
LG
rembacher
Gremlin
Post31-03-2004, 14:26    Subject: Login Code for Comfort Control Unit in Skoda Octavia Quote
Just tried it on my Octavia, works perfectly.
What kind of control unit do you have?
mine is 1C0 959 799 B 4P Comfort Control Unit HLO 0003
See you, Gremlin
rembacher
Post31-03-2004, 19:31    Subject: Comfort Control Unit Quote
Hello Gremlin!
Here are the data as I read them out using the VAG-COM 303.2:
Address: 46
Log: KW1281
Controller: 1J0 959 799 AH
Part Number: 5N Central Screw Fitting 0001
Encoding: 04097
Workshop Code: WSC 31480
Can you work with this?
LG
rembacher
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Login Code for Comfort Control Unit Diesel Engine Technology
No new posts Looking for login code for comfort control unit On-Board Diagnostics (OBD)
No new posts Skoda Octavia: Reset Oil Service Light On-Board Diagnostics (OBD)
No new posts Skoda Octavia 3 engine noise, 85 kW, 1600cc TDI Diesel Engine Technology
