Passat PD, manufactured in 1999 (85kW, approx. 85,000 km), has difficulty starting
renarenade
Post03-04-2004, 20:29    Subject: Passat PD, manufactured in 1999 (85kW, approx. 85,000 km), has difficulty starting Quote
... for the past 3 days, the engine has only started after 4-6 seconds of cranking. The problem is not temperature-dependent (neither the outside temperature nor the engine temperature). Immediately after starting, there is NO 'excessive' exhaust smoke visible. It looks like (probably) a fuel delivery system???
The performance is normal.
Does anyone have any ideas?
Thank you very much.
Bernd.
mersente
Post03-04-2004, 21:35    Subject: Passat PD, manufactured in 1999 (85kW, approx. 85,000 km), has difficulty starting Quote
Hello, do you have the ability to read the error codes?
Most likely, either the camshaft position sensor or the wiring to it is faulty.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B, Seatbelt front does not retract properly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Worn clutch disc pressure plate bearing, Golf/Bora 85KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C has difficulty starting in cold weather Diesel Engine Technology
No new posts Passat mit 1Z springt schlecht an, kein Fehlercode, Hilfe Diesel Engine Technology
No new posts Unterschiedl. Leistung Passat PD 85KW,Leistungsverlust Diesel Engine Technology
No new posts Passat 3B: Excessive Smoke Under Load - Troubleshooting Diesel Engine Technology
