WFS cannot be programmed, no response from STG.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
ddrler
Post31-08-2007, 22:44    Subject: WFS cannot be programmed, no response from STG. Quote
Hello.
Since I want to replace my engine control unit (ECU) for the Ibiza 6k ('98, part number Stg: 028 906 021 ek, wfs: 6H0 953 257 BX), I also need to have the WFS (Engine Control Unit) reprogrammed. Unfortunately, without success.
"I am able to access the Wfs Stg, however, once I click on 'Adaption', 'Login', or something similar, nothing happens or, if an action is supposed to be performed, such as reading a channel or entering a login code, nothing happens." There is no error message or anything like that; nothing happens at all.
Even with the old Stg, no reaction is detected.
Does anyone have any ideas what this could be and how to fix it?
I can easily access all other components, such as the engine.
I don't like them at all, because they only try to take advantage of me (subjectively) and in the end, I don't really get anything out of it.
I would be very grateful for any ideas.
Post31-08-2007, 23:25    Subject: WFS cannot be programmed, no response from STG. Quote
Did you enter the correct login number?
ddrler
Post01-09-2007, 11:05    Subject: WFS cannot be programmed, no response from STG. Quote
No, I don't have one, because I actually don't need it, and it's also not accepted, or I can't even access the 7-digit PIN input...
Ross-Tech-Support
CAN Support
Post02-09-2007, 19:37    Subject: WFS cannot be programmed, no response from STG. Quote
Which VAG-COM version?
ddrler
Post02-09-2007, 20:32    Subject: WFS cannot be programmed, no response from STG. Quote
is done...
Ross-Tech-Support
CAN Support
Post02-09-2007, 21:13    Subject: WFS cannot be programmed, no response from STG. Quote
Could you please explain what the problem was?
mullemaus
Post02-09-2007, 22:01    Subject: WFS cannot be programmed, no response from STG. Quote
Could you please explain what the issue was?
/viewtopic.php?p=116632#116632 This is due to several impatient responses. icon_wink.gif
Ross-Tech-Support
CAN Support
Post02-09-2007, 22:04    Subject: WFS cannot be programmed, no response from STG. Quote
Okay, so the assumption is confirmed. Now, all that's left is to go through the process of filing a criminal complaint for copyright infringement... icon_twisted.gif
No new posts Doku keine Umcodierung möglich, 01K-01F Automatikgetriebe Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wie Lenkwinkelsensor neu anlernen? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einspritzzeitpunkt AEL, keine Reaktion auf Kraftstofftemp. Diesel Engine Technology
No new posts A6 4A keine Diagnose möglich On-Board Diagnostics (OBD)
No new posts keine verbindung zum steuergerät möglich On-Board Diagnostics (OBD)
No new posts Fehler U0212 keine Kommunikation möglich On-Board Diagnostics (OBD)
