Passat 3B Repair Manual: Best Guide & Tips
bitdreher
Post28-03-2004, 21:13    Subject: Passat 3B Repair Manual: Best Guide & Tips Quote
icon_biggrin.gif Hello everyone, to all you diesel mechanics! icon_biggrin.gif
As a newcomer to the TDI world, I'm looking for a reasonable repair/service manual for my Passat Estate TDI, model year 1999 (110 hp). I don't want to disassemble the engine, but rather perform the routine maintenance myself as much as possible, and perhaps occasionally tackle a small repair.
For my Vectra B, I had the repair manual 'Jetzt helfe ich mir selbst' by Dieter Korp, which I found quite good. But when I looked around recently, I saw that repair manuals in general tend to be rated quite poorly! This also applies to the one by Dieter Korp for my Passat! icon_eek.gif
Thank you in advance!
Greetings bitdreher.
Translated on 08-10-2026, 15:29.
WarLord
Post28-03-2004, 21:51    Subject: Passat 3B Repair Manual: Best Guide & Tips Quote
How about the Etzold (How it's done)? I found it to be better for the 35i than the Korp.
Best regards, WarLord.
Translated on 08-10-2026, 15:30.
joergs
Post29-03-2004, 7:35    Subject: Passat 3B Repair Manual: Best Guide & Tips Quote
Etzhold is better, but unfortunately, even when covering interesting topics, he often only tells half the story or even gets things wrong.
I rely on www.erwin.volkswagen.de.
They are relatively expensive, but they are directly from Volkswagen.
Translated on 08-10-2026, 15:31.
bitdreher
Post29-03-2004, 21:43    Subject: Passat 3B Repair Manual: Best Guide & Tips Quote
Unfortunately, Erwin only accepts credit cards, and I think it's also quite expensive.
Is this the same Etzold? The book only has 2 stars on Amazon, which is quite low. However, it's also only based on a single review.
'I am a mechanic myself, but unfortunately, I don't have any experience with VW vehicles. Regarding maintenance and care, this book is only conditionally recommended. While you can read it as a general guide, there are significant shortcomings in the details provided.'
Water reservoir, no indication of drainage holes - these can easily become clogged and lead to water leakage inside.
Example 2: Expanding the aggregate carrier at the rear door '... can be expanded in the same way as the front.' I'm sorry, but without understanding the difference, you're at a disadvantage.
etc.
Conclusion: Rarely useful as a repair manual.
Translated on 08-10-2026, 15:32.
joergs
Post29-03-2004, 21:46    Subject: Passat 3B Repair Manual: Best Guide & Tips Quote
Sorry, but Erwin (siehe Fehlerdatenbank) also works without a credit card! Even though it's expensive, it's the best guide you can get for anything.
Etzhold and associates are simply copying and doing a very poor job of it!
Translated on 08-10-2026, 15:34.
bitdreher
Post10-04-2004, 19:43    Subject: Passat 3B Repair Manual: Best Guide & Tips Quote
Hi again,
I just bought the 'How-to Guide' by Etzold for 20 euros, and I'm actually quite satisfied with it so far. I won't really know how good the book is until I've tried out various things.
It's a bit annoying that each volume covers all versions of the Passat, including the sedan and station wagon, gasoline and diesel models. You often have to flip through a lot of pages to find the information you're looking for.
Translated on 08-10-2026, 15:35.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cylinder Head Repair Guide: 1.9 TDI 96 kW Diesel Engine Technology
No new posts "Good" workshop in Berlin? Diesel Engine Technology
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
