Connectors: Find Suppliers & Buy Online
christians
Post18-04-2004, 20:30    Subject: Connectors: Find Suppliers & Buy Online Quote
Where can one obtain the various connectors used in the engine compartment in small quantities? These are needed, for example, for discreet modifications or for building custom measurement cables.
Gruß Christian
Translated on 01-10-2026, 9:14.
Gremlin
Post18-04-2004, 20:36    Subject: Connectors: Find Suppliers & Buy Online Quote
at VW.
Alternatively, for Skoda, that's where I got my connectors for the ESP (Electronic Stability Program).
You can find almost all plugs as spare parts.
'Cu Gremlin'
Post18-04-2004, 20:57    Subject: Connectors: Find Suppliers & Buy Online Quote
Ask your Audi dealer about part numbers 443 972 983 or 443 972 984.
EDITH2: Here are the cables with a cross-sectional area of 1.0 sq mm:
000 979 118
000 979 117
(Mengen wie im u.a. Thread)
Maybe he knows what this is (the connector housings icon_wink.gif).
The contacts with cable connectors that were discussed here in the forum (for the VP37) are still relevant, as suggarmilk had asked about them before.
The parts fit my 1Z pump, but I don't know if they will fit the AAT pump.
EDITH: Probably not, because the AAT has a "round plug housing" and the (HDK-) 1Z has a "flat plug housing" ... sorry.
/viewtopic.php?t=1554&highlight=contacts+esp
Translated on 01-10-2026, 9:16.
christians
Post18-04-2004, 21:18    Subject: Connectors: Find Suppliers & Buy Online Quote
Okay, thanks. What about other connectors, such as those for the N75 valve, temperature sensor, etc.? Are the same connector types also used in other vehicles, like the Kadett?
Gruß Christian
Translated on 01-10-2026, 9:17.
Post18-04-2004, 21:29    Subject: Connectors: Find Suppliers & Buy Online Quote
Let me guess, they also have them at Audi icon_arrow.gif icon_confused.gif.
Your parts person will know where to look.
If not, I would never go back there again anyway.
Translated on 01-10-2026, 9:18.
Andy
Post19-04-2004, 7:46    Subject: Connectors: Find Suppliers & Buy Online Quote
On most connectors, you can find the part number printed in a very small font in one of the corners.
Andy.
PrivatBereich
Post19-04-2004, 18:35    Subject: Connectors: Find Suppliers & Buy Online Quote
Although the page is for the Passat and I drive a Golf, I find this link with various connectors, pictures, part numbers, and prices to be really useful.
http://www.passatplus.de/umbauteile/stecker/stecker.htm
Maybe it will also help you, as an Audi driver!
Private.
Translated on 01-10-2026, 9:19.
No new posts Compression Tester: Source & Purchase Diesel Engine Technology
No new posts Recommendation and Source: Underbody Protection Transmission, Chassis, Body & Interior
No new posts Source for gearbox gears? Transmission, Chassis, Body & Interior
No new posts VW MFD Rotary Knobs: Source & Buy Now Transmission, Chassis, Body & Interior
