Turbocharger Boost Pressure VW Golf IV 1.9 TDI
mima
Post06-04-2004, 15:22    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
I drive a Volkswagen Golf IV 1.9 TDI with 66 kW (engine code: ALH).
Does anyone know what the typical boost pressure (in bar) is for the Garrett turbocharger that's installed, and what maximum boost it can handle?
I recently read a report that the same turbocharger is used in the 90, 110, and even the 130 horsepower versions. Is that really true?
See you later...
mima
Translated on 23-08-2026, 14:21.
Julian
Post06-04-2004, 16:15    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
Nonsense...
The VTN 15 from the 90s operates with an overpressure of approximately 890 mbar.
'Models like the 110 series use different chargers.'
Translated on 23-08-2026, 14:22.
DocSnydor
Post06-04-2004, 16:23    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
Nonsense...
110s and similar models have different chargers.
Are you sure? I've read multiple times in this forum that the ALH (90 hp) and the ASV (110 hp) are identical except for the injectors and software. icon_question.gif
Translated on 23-08-2026, 14:23.
Julian
Post06-04-2004, 18:49    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
Hmm, it's possible that the 110 model also uses a VTN15 compressor, but with a different impeller design; I'm not sure about that.
Definitely the 115.
The 130 and 150 models have slightly different VTN17 specifications.
Translated on 23-08-2026, 14:24.
Post06-04-2004, 19:46    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
Hi.
These devices are called VNT, which stands for Variable Nozzle Technology.
ALH and AJM engines have the same turbocharger!
Translated on 23-08-2026, 14:25.
Post06-04-2004, 20:00    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
Take a look at the technical article with the target values for the different engines.
That also includes the turbocharger pressure.
Julian
Post06-04-2004, 20:03    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
Yeah, you're right. But I usually just say GT15 etc... icon_wink.gif ...although hardly anyone understands that either.
Translated on 23-08-2026, 14:26.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post06-04-2004, 20:52    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
The 130 hp PD engine definitely has a 17-inch turbocharger, while the 2.5 TDI engine uses a VNT 20 turbocharger.
I'm not sure about the ALH, but it's probably the same as the AFN with the VNT 15.
The VNT 15 can withstand a continuous pressure of up to 1.2 bar.
VNT 20, 2 bar, boost pressure.
"I got this information from a workshop that specializes in tuning VAG TDI engines."
Unfortunately, the VNT 20 is only conditionally recommended for use with the 1.9 TDI engine because it doesn't really start to function properly until around 2000 RPM. icon_smile.gif
B.Eng (FH) u. KFZ Meister
Translated on 23-08-2026, 14:27.
Gremlin
Post07-04-2004, 16:04    Subject: Turbocharger Boost Pressure VW Golf IV 1.9 TDI Quote
Here is the nameplate from my ALH loader:
http://www.ralfhandel.de/images/turbo-typenschild.jpg
CU Gremlin.
Translated on 23-08-2026, 14:28.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Pfeifgeräusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger: High Boost Pressure Causes Failure? Diesel Engine Technology
No new posts VW Golf ALH Turbo: Top or Bottom Removal? Diesel Engine Technology
No new posts Boost Pressure Difference VW Golf III Diesel Engine Technology
No new posts STG Golf III AFN: No Boost Sensor Connection? On-Board Diagnostics (OBD)
