High consumption (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post02-05-2002, 13:39    Subject: High consumption Quote
In TDIs with a VP37 injection pump, if the injection timing is incorrect (due to an improperly set base setting or a faulty adjustment mechanism) and/or the injectors are worn, the fuel will not be used efficiently.
A heavily soiled air filter not only leads to increased soot production but also increases fuel consumption. Similarly, leaks in the charge air system (caused by rodents, cracks, or chafed hoses) can cause problems.
Translated on 12-07-2026, 12:29.
mersente
dieselschrauber likes this.
Post19-02-2004, 21:38    Subject: High consumption Quote
Hello Rainer, a faulty mass airflow sensor (MAF) can also lead to increased fuel consumption, as the accelerator pedal is often pressed more to demand more power.
Translated on 12-07-2026, 12:30.
Ratings - High consumption
No new posts 1.4 TSI CTHA - Fuel consumption figures Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts High fuel consumption (approx. 8 liters) on ALH TDI engine On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Audi A6 Avant: High Fuel Consumption (DPF) Diesel Engine Technology
No new posts High consumption and Russian education Diesel Engine Technology
No new posts High fuel consumption - need help On-Board Diagnostics (OBD)
