ASV as a 3-cylinder engine
mcgregg
Karma: +7 / -1   Thank you, like it!
Post12-04-2004, 17:08    Subject: ASV as a 3-cylinder engine Quote
Hello everyone,
After standing for 4 days, my Octavia started perfectly this afternoon, aside from the starter motor noise that was already discussed in another thread. However, after about 100 meters of driving, the engine was only running on 3 cylinders. After about two minutes of idling and another 500 meters, the problem disappeared.
Could it be that an injector valve sometimes fails to open? How do worn-out injector valves manifest themselves?
mcgregg
Skoda Octavia II Combi TDI, 2012, 103kW/140PS MKB CFHC
Translated on 08-07-2026, 8:49.
donalexo
Post12-04-2004, 22:57    Subject: ASV as a 3-cylinder engine Quote
/Speculation mode on
Well, maybe there was just an air bubble that made its way from the fuel system into the high-pressure line of a cylinder.
After the line was bled again after a short time, the engine ran perfectly again.
/speculation mode off
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 08-07-2026, 8:50.
mcgregg
Post13-04-2004, 6:10    Subject: ASV as a 3-cylinder engine Quote
donalexo wrote:
/Entering speculation mode.
Alex
Jo, das klingt logisch. Am Auspuff war auch alles normal, so daß Kraftstoffmangel sehr wahrscheinlich ist. Auf die Idee mit der Luftblase war ich nicht gekommen. Danke. icon_smile.gif
This morning, everything went completely normally again.
mcgregg
Translated on 08-07-2026, 8:51.
No new posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts 5-Cylinder TDI Engine: Performance & Specs Diesel Engine Technology
No new posts Tiptronic: 4-Cylinder Engine Performance Diesel Engine Technology
No new posts Golf 4 with a 3-cylinder engine Gasoline Engine Technology
No new posts TDI Cold Start Problems: Audi A6 5-Cylinder Diesel Engine Technology
