Idling Speed Control: 130 HP PD Yesterday
WarLord
Post17-10-2004, 18:37    Subject: Idling Speed Control: 130 HP PD Yesterday Quote
Yesterday, I had the pleasure of reading out a 130 HP PD engine. Everything seemed fine so far, but one thing seemed a bit suspicious: In the idle speed control, there was a deviation of 2 mg/stroke between cylinder 1 (-1 mg/stroke) and cylinder 4 (icon_smile_thumb_up.gif mg/stroke). Cylinders 2 and 3 were normal (around 0 mg/stroke). However, the car didn't jerk, and it drove normally. Why is this? Normally, something like this should cause jerking, right?
Best regards, WarLord.
Translated on 10-10-2026, 13:04.
Post17-10-2004, 18:40    Subject: Idling Speed Control: 130 HP PD Issues Yesterday Quote
WarLord wrote:
Usually, something like that should make itself known by jerking or shaking, right?
I think the stuttering only occurs when the system is ramping up.
That can happen, but it doesn't have to.
Translated on 10-10-2026, 13:05.
WarLord
Post17-10-2004, 19:25    Subject: Idling Speed Control: 130 HP PD Yesterday Quote
Hm, okay. Wasn't there also something about having to replace the PD elements if they deviate too much? Or was that only the case if there's a jerky movement?
Translated on 10-10-2026, 13:06.
donalexo
Post17-10-2004, 19:30    Subject: Idling Speed Control: 130 HP PD Yesterday Quote
Hello WarLord!
The values only indicate that there are differences between the individual cylinders. However, the active control compensates for these differences, so that (ideally) no more vibrations occur.
If all cylinders were supplied with the same amount of fuel injection, then an uneven torque output would result. icon_wink.gif
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 10-10-2026, 13:07.
Julian
Post17-10-2004, 19:43    Subject: Idling Speed Control: 130 HP PD Yesterday Quote
A deviation of up to 3mg per cylinder is permitted!
WarLord
Post18-10-2004, 17:39    Subject: Idling Speed Control: 130 HP PD Yesterday Quote
Okay, then I probably had incorrect information.
I'm glad that everything seems to be fine with me, as our PD (presumably referring to a medical test or measurement) shows very little difference between the cylinders.
Translated on 10-10-2026, 13:08.
Post18-10-2004, 18:59    Subject: Idling Speed Control: 130 HP PD Yesterday Quote
Mine also only shows very minimal values around 0, evenly across all 4 cylinders. Strangely, even during the minimal warm-up roughness...
No new posts Calix Motor Heater Installation Guide Troubleshooting & Guides
No new posts I finally managed to get a 1551 stuck again today... Diesel Engine Technology
No new posts TD Speeds: Yesterday and Today Diesel Engine Technology
No new posts Has anyone experienced this before? Diesel Engine Technology
No new posts Audi A6 2.5 TDI Problem: Won't Start? On-Board Diagnostics (OBD)
