Disassembling the metering unit of a VP37 (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Troubleshooting & Guides
marcello Post04-04-2004, 10:43
The following article is by Marcello, thank you very much! I would also like to thank Tuppie, who added more pictures and tips to the article.
The manual describes the disassembly/assembly process and the correct readjustment of the dosing valve.
Cleaning the setpoint adjustment mechanism can eliminate jolts or vibrations caused by debris or general dirt accumulation.
VCDS is recommended for calibrating the flow control valve.
Anleitung zum Zerlegen eines Mengenstellwerkes.pdf
 Mengenstellwerk einer Bosch VP37 Einspritzpumpe Zerlegen und erfolgreich wieder in Betrieb nehmen.
 File name:  Anleitung zum Zerlegen eines Mengenstellwerkes.pdf
 File size:  1010.88 KB
 Downloaded:  113855 times
Translated on 11-07-2026, 23:13.
Ratings - Disassembling the metering unit of a VP37
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 12 - View ratings
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts Function and components of an air conditioning system Technical Articles
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts VP44: Seal & Disassemble - Repair Guide Diesel Engine Technology
No new posts VP37: Troubleshooting Internal Housing Issues Diesel Engine Technology
This topic is locked, you cannot edit or reply. Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine... Diesel Engine Technology
No new posts RCD 510 with an antenna? Electrical Systems, Vehicle Electronics, Multimedia
