Dynamically adjusting the timing belt on a T4 2.5 TDi
karam09
Post19-04-2006, 20:08    Subject: Dynamically adjusting the timing belt on a T4 2.5 TDi Quote
I'm having trouble reading group 0000 (under basic settings). When I try to read it with VAG software (version 3.112), the engine shuts off... what could be causing this?
I can't access the values for a dynamic setting.
Who has an idea or a solution?
T4 engine code AJT, manufactured in 2001.
The car is running well overall, but the fine-tuning isn't working.
Best regards, Karam.
Translated on 23-07-2026, 8:14.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
This topic is locked, you cannot edit or reply. T4 TDI: Dynamically Adjust Injection Timing with Bosch KT... Diesel Engine Technology
No new posts Dynamically check and, if necessary, adjust the start of ... On-Board Diagnostics (OBD)
No new posts Adjusting VP44 dynamically -> Problems Diesel Engine Technology
No new posts 1.4 TSI timing belt valve timing adjustment Gasoline Engine Technology
