High-Speed Vibrations: Causes and Solutions
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
GerTDi
Post08-05-2004, 22:16    Subject: High-Speed Vibrations: Causes and Solutions Quote
I've noticed the following problem: My Bora Variant AJM '00 (with approximately 100,000 km) has recently started to exhibit vibrations in the steering wheel (which are noticeable, even if only slightly), starting around 180 km/h.
I noticed this after I installed the summer tires. I didn't drive as fast with the winter tires, so I'm not sure if it's related. I might do a test if necessary.
What surprises me is that the vibrations only occur at such a high speed; at lower speeds, nothing is noticeable. I've only experienced vibrations caused by unbalanced tires at around 100 km/h.
The vibrations are noticeable at a constant speed above 180 km/h and become stronger when accelerating, with the intensity increasing with more load. Searching in this forum has not yielded any relevant results, except for a vague suggestion about the engine mounts.
Okay, the brake discs are quite worn, and there's a very slight vibration when braking gently at speeds above 15 km/h. Could that be related?
Any ideas?
Gerd.
Translated on 24-10-2026, 6:50.
Julian
Post09-05-2004, 9:24    Subject: High-Speed Vibrations: Causes and Solutions Quote
Idea, sure, always...
1) Rebalance and mount the tires.
2) Ensure the rims are mounted evenly and tighten the lug nuts securely. Don't forget to re-tighten them after approximately 100 km (60 miles).
Tip:
When the technician removes the tire from the balancing machine and lets it fall to the floor so he can roll it to the car, he's going to have to put it back on the machine to be balanced again.
Translated on 24-10-2026, 6:52.
Wurstblinker
Post09-05-2004, 11:23    Subject: High-Speed Vibrations: Causes and Solutions Quote
Tip:
When the technician takes the tire off the balancing machine and lets it fall to the floor so he can roll it to the car, he's going to have to balance it again...
Why is that?
'MFG' is an abbreviation for 'mit freundlichen Grüßen,' which means 'best regards' or 'sincerely.' It is commonly used in German-language emails and letters.
Translated on 24-10-2026, 6:54.
GerTDi
Post09-05-2004, 11:24    Subject: High-Speed Vibrations: Causes and Solutions Quote
Okay, I just had a chance to test it out.
The vibrations occur between approximately 170 and 190 km/h. They do not disappear when you release the accelerator and disengage the clutch, so I believe that driving-related factors are not the cause.
When braking from the aforementioned speed down to approximately 80 km/h no vibrations occur. I have tested this multiple times, both with gentle and relatively hard braking.
Could the vibrations also be coming from the braking system? The brake discs are quite worn, but still within the acceptable tolerance range.
Next, I'm going to have the tires balanced. Can you also detect runout on a standard balancing machine? Can the mechanic do this on their own, or do I need to give them a tip?
edit:
Tip:
When the technician takes the tire off the balancing machine and lets it fall to the floor so he can roll it to the cart, he's going to have to balance it again...
Why is that?
I don't understand it either. Every bump in the road causes a harder impact. Then I would essentially have to have the tires re-balanced after every manhole cover. Or would I?
Translated on 24-10-2026, 6:55.
Julian
Post09-05-2004, 11:25    Subject: High-Speed Vibrations: Causes and Solutions Quote
You can tell if a wheel has run true by whether or not it can be balanced.
Were the tires not balanced this time?
Translated on 24-10-2026, 6:57.
Julian
Post09-05-2004, 11:27    Subject: High-Speed Vibrations: Causes and Solutions Quote
Why is that?
Because the tire will likely have the same imbalance again, at least to the same extent as before it was balanced. It doesn't even have to fall off completely.
A good mechanic is recognized by the fact that they carefully place the tire down, rather than throwing it.
Translated on 24-10-2026, 6:58.
GerTDi
After this winter rotation schedule, not. Should I have...? Frugality is awesome icon_redface.gif icon_cool.gif.
Julian
Post09-05-2004, 11:29    Subject: High-Speed Vibrations: Causes and Solutions Quote
Not after this winter rotation schedule. Should I have...? Frugality is awesome icon_redface.gif icon_cool.gif.
Balancing should always be done! Here, balancing with lead adhesive weights costs about €4.50 per wheel... so where is the 'being cheap is good' mentality?
Your entire suspension system will thank you for it...
Translated on 24-10-2026, 6:59.
GerTDi
Post09-05-2004, 11:33    Subject: High-Speed Vibrations: Causes and Solutions Quote
Well, it's less about being stingy and more about laziness icon_redface.gif.
Do I need to clean the rim before applying the adhesive weights, or do the technicians have something for that?
Translated on 24-10-2026, 7:00.
Julian
Post09-05-2004, 11:42    Subject: High-Speed Vibrations: Causes and Solutions Quote
Do I need to clean the rim before applying the adhesive weights? Or do the mechanics have something for that?
Rims should be cleaned before being stored. It costs about 1-2€ if you have them steam-cleaned at a car wash... icon_wink.gif
You can leave the old adhesive weights on; there's a plastic chisel you can use to remove them gently. A technician won't clean them off for you.
Translated on 24-10-2026, 7:01.
GerTDi
Post09-05-2004, 11:49    Subject: High-Speed Vibrations: Causes and Solutions Quote
The wheels are already mounted, so they're definitely dirty, at least on the inside. Will the weights stay in place?
He should only clean the area where the weights are attached, so that they don't immediately fall off again if they don't stick properly to the dirty rim. In my opinion, this is already part of a proper balancing procedure.
Julian
Post09-05-2004, 13:12    Subject: High-Speed Vibrations: Causes and Solutions Quote
Are you extremely lazy, or what?
Sure, you can also just clean the areas where the balancing weights will go, but how do you know beforehand which areas need to be cleaned before balancing?icon_rolleyes.gif
Translated on 24-10-2026, 7:02.
No new posts Documentary about vibrations starting at approximately 12... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vibration at Acceleration: Causes & Fixes General Tips
No new posts Shaky Ride at 70 mph: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Diesel Engine Technology
No new posts Passat 1Z with excessive boost pressure Upload
No new posts Steering Wheel Vibration Above 80 km/h? Transmission, Chassis, Body & Interior
