Wave Acceleration on 2.5L V6 6Zyl Engine
Johannes
Post19-06-2002, 21:33    Subject: Wave Acceleration on 2.5L V6 6Zyl Engine Quote
My A6 is accelerating in a wavy pattern.
The thrust steadily increases up to 3000 RPM, then the power briefly drops. The same thing happens again at 3500 RPM.
Does anyone have any advice?
John.
Translated on 02-08-2026, 10:32.
Uwe
Post19-06-2002, 22:43    Subject: Wave Acceleration on 2.5L V6 6Zyl Engine Quote
Hi!
Mildly wavy acceleration accompanied by a loss of power often indicates a faulty mass airflow sensor (MAF). This part can be replaced in just a few minutes. Therefore, a test drive with a different MAF sensor is recommended for diagnosis.
Uwe
Translated on 02-08-2026, 10:33.
Michael II
Post20-06-2002, 8:57    Subject: Wave Acceleration on 2.5L V6 6Zyl Engine Quote
If you have the opportunity, start by reading the measurement data blocks. An overview can be found in the error database.
Tschüss
Michael II
Translated on 02-08-2026, 10:34.
No new posts Beschleunigung wellenförmig: Ursachen beim TDI Technical Articles
No new posts Target values for 6-cylinder engines. VP AYM Technical Data
No new posts Beschleunigung endet vor Vmax General Tips
No new posts Leichtes Ruckeln bzw. wellenförmige Beschleunigung Diesel Engine Technology
No new posts Volvo V70 TDI with Audi/AEL wave-like acceleration Diesel Engine Technology
No new posts Wellenförmige Beschleunigung beim ALH Upload
No new posts Polo 9N3 1,4 TDI DPF BWB ruckeln, wellenförmige Leistung Diesel Engine Technology
