Power windows with built-in intelligence?
Fireball
Post11-05-2004, 22:10    Subject: Power windows with built-in intelligence? Quote
Last weekend, I replaced the driver's side door lock on my Passat 3B (AFN) (you know, the microswitch... icon_wink.gif), and I almost had a heart attack when I tested the lock and the central locking on the driver's side didn't work: it only worked on the other doors and the trunk.
In this test, the entire interior trim, including the window regulators, was removed. After the window regulator motor was reconnected, everything worked perfectly. Okay, that's nice and good, but I'm still surprised that this seems to be related to the window regulator motor. So, how does that contribute to the door locking mechanism, especially since VW doesn't have any comfort closing functions...?
Marcus.
R00KIE
Post11-05-2004, 23:10    Subject: VETO Quote
It might icon_rolleyes.gif not contribute much to solving your problem, but VW offers a comfort closing feature. My G3, manufactured in 1994, has four power windows and an electric sunroof, and until about a year ago, it would close everything when holding the key fob in the 'close' position and open all the windows when holding it in the 'open' position. Now, it only controls the windows, because the sunroof's cable is broken, and I've disconnected it.
R00KIE
Fireball
Post12-05-2004, 0:03    Subject: Power windows with built-in intelligence? Quote
Okay, I also have this type of locking mechanism. I was referring to the Audi-specific locking system that works via the remote control. However, I don't see a real connection between that and the central locking system not working via the remote control, since the remote control doesn't affect the power windows...
Gremlin
Post12-05-2004, 9:05    Subject: Power windows with built-in intelligence? Quote
That's not just the window lifter...
The device is called the door control module, and the central locking and mirror actuators are connected to it.
And the one located in the driver's door is essentially the main control unit. All the window switches, mirror adjustments, and central locking buttons are connected to it. Furthermore, it initiates the automatic window opening and closing function.
CU Gremlin.
Fireball
Post12-05-2004, 10:18    Subject: Ahaaaa... Quote
That's a real eye-opener, thanks. I somehow didn't expect that the entire door control unit was essentially integrated into the window motor icon_smile.gif - and it wasn't really apparent from the existing wiring harness icon_smile.gif.
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Window lifter: Repair tip for Golf IV platform Troubleshooting & Guides
No new posts Doku Luop 6X1 MJ 2002, Window regulators stiff Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electric Window Driver Door Diesel Engine Technology
No new posts Polo 9N window lifter On-Board Diagnostics (OBD)
No new posts Golf 4 Window Regulator Replacement Transmission, Chassis, Body & Interior
No new posts Electric Window Failure: Complete System Malfunction Diesel Engine Technology
