Magnetic valve for charging pressure regulation (24-06-2002, 11:38)
Marko
Post24-06-2002, 11:38    Subject: Magnetic valve for charging pressure regulation Quote
Hi!
Drive the '96 A6 2.5 TDI AAT.
Is it possible to manipulate the valve, or increase the intake pressure, without interfering with the ECU?
cu: Marko
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Control Valve: Limit Charge Pressure Diesel Engine Technology
This topic is locked, you cannot edit or reply. Magnetventil für Ladedruckbegrenzung Diesel Engine Technology
No new posts Ladedruckbegrenzung On-Board Diagnostics (OBD)
No new posts Boost Pressure Problems: N75 & Manifold Pressure Sensor Diesel Engine Technology
