PCMCIA Adapter: VAG COM Serial Interface
Mc_Givertechnik
2010 Volkswagen T5
Post13-05-2004, 6:20    Subject: PCMCIA Adapter: VAG COM Serial Interface Quote
Hello!
Since newer laptops no longer have serial ports, I purchased a serial PCMCIA card so I can continue to use my VAG COM adapter. Everything works fine with the card on the laptop, and it allows me to use serial devices without any problems (mouse, Nokia data cable, old printer).
Unfortunately, my new laptop cannot find the VAG COM adapter using this interface. The LED test works fine. The error message is something like: "Serial Port found, Adapters found 0..." or similar.
Does anyone have experience with this? The COM interface is configured the same way as it was on the old notebook.
"Of course, I'm not brave enough to deactivate my old, purchased license right now, because there's no guarantee that it will work on the new laptop. Could this also be due to the VAG COM version (302.2)?"
Please help.
Greetings.
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 16-10-2026, 23:48.
Rudi
Post13-05-2004, 8:45    Subject: PCMCIA Adapter: VAG COM Serial Interface Quote
Hello Peter,
Please provide the exact message.
'0' actually means 'okay' (see the picture).
Best regards, Rudi.
 File size:  8.19 KB
 Viewed:  2798 times
Translated on 16-10-2026, 23:49.
Post13-05-2004, 8:48    Subject: PCMCIA Adapter: VAG COM Serial Interface Quote
As I understand it, VAG-COM performs a loop-back test during the adapter test.
So, if it doesn't work, it's probably because the time difference between the transmission (Tx) and reception (Rx) of the same data is too large.
Try using something like "TestAdapter:ok.zip" or a similar file from a diagnostic article to determine if the loop-back functionality works in principle and up to what baud rate.
Translated on 16-10-2026, 23:50.
Mc_Givertechnik
2010 Volkswagen T5
Post13-05-2004, 11:17    Subject: PCMCIA Adapter: VAG COM Serial Interface Quote
@RudiViewing profile: Rudi
"I am getting this exact error message. However, I am unable to establish a connection with any control unit. I have also gradually reduced the baud rate, but unfortunately, nothing worked."
@ Rainer.K
I will search for the file and report back.
Thank you for your help.
Greetings, Peter.
Translated on 16-10-2026, 23:51.
Post13-05-2004, 11:23    Subject: PCMCIA Adapter: VAG COM Serial Interface Quote
This is not an error message, but rather indicates that the adapter has been found, but it is not compatible with "fast-sync" (see professional adapters).
Also eigentlich alles im grünen Bereich, warum es trotzdem nicht klappt? No idea...
Translated on 16-10-2026, 23:52.
Mc_Givertechnik
2010 Volkswagen T5
Post13-05-2004, 18:28    Subject: PCMCIA Adapter: VAG COM Serial Interface Quote
Okay, everything has been tested.
The loopback test resulted in a baud rate of 9600. The other test yielded no results.
I can access the instrument cluster, but all the other control units are denying me access!
What now?
Greetings,
Peter.
Translated on 16-10-2026, 23:53.
Post13-05-2004, 19:34    Subject: PCMCIA Adapter: VAG COM Serial Interface Quote
Well, that's a bit too little... I'm not sure, is there a driver update or something like that for that PCMCIA device?
Mc_Givertechnik
2010 Volkswagen T5
Post14-05-2004, 5:07    Subject: PCMCIA Adapter: VAG COM Serial Interface Quote
Could adjusting the potentiometers achieve any positive results? Since the adapter works perfectly fine on the old laptop (P120), I actually didn't want to modify anything on the adapter itself.
Greetings, Peter.
Translated on 16-10-2026, 23:54.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts Adapter Diesel Engine Technology
No new posts USB K-Line Adapter: Buy Now! Diesel Engine Technology
No new posts OBD2 adapter Diesel Engine Technology
