Gearbox letter codes correspondence
Bolzer
Karma: +14 / -0   Thank you, like it!
Post16-05-2004, 22:49    Subject: Gearbox letter codes correspondence Quote
Hi.
I'm planning to extend the 5th gear on my EGS gearbox. I've already found some information using the search function, but I also found two more gearboxes on a list that have an even smaller ratio: the DRZ and the DUS gearboxes. Now my question is: which engines are these gearboxes designed for?
Best regards, Bolzer.
Translated on 12-07-2026, 17:31.
No new posts VW Car Engine Codes: Type, MKB, GKB, AKB, MJ Technical Data
No new posts VW Commercial Vehicle Type Designation, Engine Code, Gear... Technical Data
No new posts Zuordnung Audi Typ, MKB, GKB, AKB, MJ Technical Data
No new posts Turbocharger Part Number Cross-Reference (AFN) Diesel Engine Technology
No new posts Brake line routing on the ABS hydraulic block Transmission, Chassis, Body & Interior
