Unfortunately, my rear left window has stopped working - more specifically, it still functions, but the window glass seems to have come off its tracks.
Meine eigentliche Frage: wie bekommt man die vermaledeite Verkleidung weg? Die Schraube unten öffnen ist klar, aushängen aus den Schnappverschlüssen auch, allerdings habe ich den Eindrunck, dass das Teil ähnlich wie bei den vorderen Türen noch in der Nähe der Griffe verschraubt ist, konnte aber nicht rausfinden, wo. IrgenWhat clues?
It's quite simple: you need to remove the cover (you can pry it open, preferably carefully with a screwdriver). Underneath, you'll find a few screws, and then you can detach it by lifting it upwards.
Be careful, the small plastic noses can break off easily.
Normally, there seems to be some kind of stopper that connects the glass to the lifting mechanism - that's missing .
I was hoping the mechanism would be the same as the one in the front, where the glass is simply clamped in place with two screws – but no such luck. Does anyone happen to have a parts catalog handy and could look up the part number for me? I don't have one yet...
