TDI Cold Start Problems: Audi A6 5-Cylinder
Honk
Post12-05-2004, 8:29    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
Hello.
'For some time now, I've been having a problem with my Audi A6 C4, manufactured in 1996 (2.5L, 140 hp, AEL engine, 165,000 km). When the engine is cold, it starts poorly. I have to crank it for a while. Sometimes it only starts on the second attempt. Once it's started and still somewhat warm, it starts immediately.'
Does anyone else experience this problem, and does anyone have any idea what might be causing it?
I hope this question hasn't been asked and answered a thousand times already. I couldn't find anything relevant in my search.
Translated on 25-10-2026, 14:52.
Andy
Post12-05-2004, 8:40    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
I would investigate the possibility of adjusting the injection timing.
Could the starting problem be related to a recent timing belt replacement? If so, the injection timing may not have been set correctly during the procedure.
Otherwise, there's also the preheating system, which is unlikely to be relevant given the current weather conditions, or air bubbles in the fuel lines.
Andy.
Translated on 25-10-2026, 14:54.
Honk
Post12-05-2004, 8:54    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
Otherwise, there's also the glow plug system, which is unlikely to be the issue given the current weather conditions, or there might be air bubbles in the fuel lines.
Andy
Hello.
The last timing belt replacement was 1 1/2 years ago.
Air bubbles?? Hmm, I'll try replacing the fuel filter.
What about the fuel injectors? Could they be the cause of the problem, or is it unlikely? Besides the cold start issues, the car runs great.
Translated on 25-10-2026, 14:55.
Julian
Post12-05-2004, 9:02    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
1) If there's air in the system, the engine will misbehave, not just during the cold start phase.
2) Leave the diesel filter in; it has nothing to do with the cold start phase.
3) The start of injection will be correct; otherwise, the engine would exhibit problems in other ways, not just during the cold start phase.
4) Replace the coolant temperature sensor, and that should fix it, as it's closely related to the cold start phase.
Translated on 25-10-2026, 14:57.
christians
Post12-05-2004, 11:36    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
Julian wrote:
3) The start of injection will be correct; otherwise, the engine would exhibit problems in other areas, not just during the cold start phase.
That's not the case. I'm just referring to Hähnlein's well-known mega-thread.
Gruß Christian
Translated on 25-10-2026, 14:58.
Andy
Post12-05-2004, 15:29    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
A car engine operates in its cold start phase when it has cooled down due to prolonged inactivity. It is precisely during this phase that even the smallest leaks in the fuel system, caused by air entering, become significant. We have already seen numerous cases of various leaks between the ESP (Electronic Stability Program) and the fuel tank, which led to starting problems.
Apart from that, the coolant temperature sensor is, of course, also a likely culprit...
Andy.
Translated on 25-10-2026, 14:59.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post12-05-2004, 18:07    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
Please tell me your mileage.
The injectors may be leaking.
Can the pressure relief valves on the pump head be defective?
Can the start of the injection be adjusted?
Coolant sensor.
B.Eng (FH) u. KFZ Meister
Translated on 25-10-2026, 15:00.
Honk
Post18-05-2004, 11:05    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
Could you please write down your mileage?
Coolant sensor.
165,000 km
Battery is 3 months old.
Now that it's warmer, with an outside temperature of around 17°C, it starts up better. So it seems that the temperature range between approximately 7°C and 15°C is causing problems. I'll try to have my mechanic read the car's diagnostic system in the next few days.
Translated on 25-10-2026, 15:01.
christo
Post18-05-2004, 16:43    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
Regards
Hello!
That, in turn, sounds more like a preheating system!
Best regards, Christo.
Skoda Octavia III Combi (5E5), EZ: 6/2016, 2.0 TDI 110 kW (MKB: CRMB), 6-Gang-Schaltgetriebe (GKB: PGT)
Translated on 25-10-2026, 15:03.
Karma: +807 / -0   Thank you, like it!
Post18-05-2004, 17:14    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
christo wrote:
Regards
Hello!
For TDIs, the glow plug system is not necessary for starting the engine when the temperature is above approximately 5°C.
Translated on 25-10-2026, 15:04.
Markus H.
Post18-05-2004, 22:12    Subject: TDI Cold Start Problems: Audi A6 5-Cylinder Quote
I would like to test the start of the injection.
He is definitely a candidate (based on my own experience).
In my case, it was due to the timing belt replacement.
If it's been a while since your last injection, and you suspect the problem might be related to the injection process, you should check if the device has been adjusted unintentionally.
Translated on 25-10-2026, 15:05.
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts AFN Cold Start Problems Diesel Engine Technology
No new posts T4 2.5 TDI ACV: Cold Start Problems Upload
No new posts Cold start problems with BLS 1.9 TDI engine Diesel Engine Technology
No new posts A6 AAT cold start problems, the umpteenth... Diesel Engine Technology
