Rear Door Panel Passat 3B
Fireball
Post13-05-2004, 23:00    Subject: Rear Door Panel Passat 3B Quote
Unfortunately, my rear left window has stopped working - more specifically, it still functions, but the window glass seems to have come off its tracks.
Meine eigentliche Frage: wie bekommt man die vermaledeite Verkleidung weg? Die Schraube unten öffnen ist klar, aushängen aus den Schnappverschlüssen auch, allerdings habe ich den Eindrunck, dass das Teil ähnlich wie bei den vorderen Türen noch in der Nähe der Griffe verschraubt ist, konnte aber nicht rausfinden, wo. IrgenWhat clues?
Greetings.
Marcus.
Translated on 13-10-2026, 3:17.
Sir Tortsch
Post14-05-2004, 21:33    Subject: Rear Door Panel Passat 3B Quote
It's quite simple: you need to remove the cover (you can pry it open, preferably carefully with a screwdriver). Underneath, you'll find a few screws, and then you can detach it by lifting it upwards.
Translated on 13-10-2026, 3:18.
Fireball
Post15-05-2004, 0:26    Subject: Rear Door Panel Passat 3B Quote
Thank you icon_smile.gif.
I had already suspected that, but I didn't dare to try to pry it open more forcefully, because everything was so tightly stuck... icon_rolleyes.gif
Translated on 13-10-2026, 3:19.
Sir Tortsch
Post15-05-2004, 10:20    Subject: Rear Door Panel Passat 3B Quote
Yes, there are metal pieces underneath icon_cool.gif that sometimes bend, but that's not a problem } because you can easily bend them back into shape.
Did the glass just pop out of its frame, or is it broken? Did you manage to fix it?
Fireball
Post17-05-2004, 10:51    Subject: Rear Door Panel Passat 3B Quote
Normally, there seems to be some kind of stopper that connects the glass to the lifting mechanism - that's missing icon_rolleyes.gif.
I was hoping the mechanism would be the same as the one in the front, where the glass is simply clamped in place with two screws – but no such luck. Does anyone happen to have a parts catalog handy and could look up the part number for me? I don't have one yet...
Translated on 13-10-2026, 3:20.
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Repair: Rear Hatch Lock Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter T4: Rear Door Lock Malfunction Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Passat Brake Pad Replacement & Door Panel Removal Transmission, Chassis, Body & Interior
No new posts Passat 3C Rear Brake Adjustment Procedure Transmission, Chassis, Body & Interior
No new posts Passat Variant - Rear bumper, assembly Transmission, Chassis, Body & Interior
No new posts VW Passat Rear Door Won't Open - Fix! Transmission, Chassis, Body & Interior
