Eum76 wrote: |
Voltage at the control panel (measured across the battery):
Engine off: 12.4V
Motor on: 14.4V
Full throttle: 14.6V |
I would still consider that to be normal.
Quote: |
| When the glow plugs are switched off, the oscilloscope shows a voltage spike of approximately 18 V for about 20 ms. |
Hmm, in my opinion, shouldn't the battery "absorb" such voltage spikes?
Did you actually measure that directly at the battery, or somewhere else in the vehicle's electrical system?
If that's the case, there might be a resistance or loose connection somewhere in the charging cable (or even the ground!) between the alternator (LiMa) and the battery.
