Hello.
I'm having a problem with a Golf IV with an AUS engine:
After giving it
gas, you wait 0.5-1 seconds for the engine to react, and then, in my opinion, it increases its RPM a bit too slowly. So, based on my feeling, you're probably traveling at around 40-50 horsepower ('
Otherwise, it runs fine, with an A1 rating and a top speed of up to 210 km/h according to the speedometer. The idle is also perfect, very stable and smooth.
Error memory is clear, throttle body is clean and not sticking.
When you increase the speed while it's stationary, the throttle valve opens relatively slowly, but without sticking.
I've also heard that this issue occurs more frequently with the 1.6 16V engine, and that the dealership often replaces the engine control unit (ECU).
Can someone confirm this?
"If so, which ECUs were faulty, and what is the replacement? Perhaps someone has the corresponding part numbers."
What is the goodwill/discount offered for a vehicle manufactured in 2001?
I am grateful for any help.
Voss.
