TDIspeed Guest
21-05-2004, 11:18 Subject: 6-speed transmission compatibility with AFN engine? |
Ich habe gerade auf ebay ein günstiges 6 Gang Getriebe gefunden. Es stammt von einem 4er Golf oder Bora mit dem 150PS TDI PD Motor. Ist es möglich dieses Getriebe an meinen AFN Motor zu flanschen oder muss man da extrem viel ändern? Angeblich lassen sich diese Getriebe ja spielend leicht in einen G60 oder 1,8 turbo verbauen, bleibt nur die Frage ob es auch an einen älteren 1,9 TDI passt. WaWhat do you think?
Please help!
Link to the auction:
http://cgi.ebay.at/ws/eBayISAPI.dll?ViewItem&category=61168&item=7902763041&ssPageName=STRK:MESSE:IT
Translated on 03-10-2026, 16:09.
BlauBaer Guest
21-05-2004, 23:06 Subject: 6-speed transmission compatibility with AFN engine? |
We had this discussion before, as far as I remember. The starter motor also had to be replaced, and something else (drivetrain?). It's best to use the search function; you'll find more information there.
best regards, BB
Steffarn Profi-Schrauber
22-05-2004, 12:15 Subject: 6-speed transmission compatibility with AFN engine? |
Into which car is the 6-speed gearbox supposed to go?
Afn engines are found in many cars.
Quer u. Built-in lengthwise.
With the Audi A4, I know when you might need a different aggregate carrier and a suitable shift console.
B.Eng (FH) u. KFZ Meister
Translated on 03-10-2026, 16:10.
Profile PM Email Garage |
TDIspeed Guest
23-05-2004, 11:28 Subject: Golf 3 AFN: Specs, Problems, & More |
Okay, so the transmission is going to be installed in a Golf 3.
What concerns me most is whether the clutch and half-shafts will actually work together properly.
Best regards, Viktor.
