Engine Injectors: Which Motor?
Wurstblinker
Post07-06-2004, 19:27    Subject: Engine Injectors: Which Motor? Quote
Could someone please check which specific 1.9 TDI engine it is based on the following VW part number?
028 130 2010 B00 // 130 / 300 bar
It would be really nice if someone could tell me.
Thank you very much.
Sausage blinkers.
Translated on 22-09-2026, 19:27.
PrivatBereich
Post07-06-2004, 20:06    Subject: Engine Injectors: Which Motor? Quote
Just type 'Bosch Ecat' into Google. Then, enter the part number and it will show you the vehicles that are compatible with that part.
Wishing you lots of fun!
-Private
Translated on 22-09-2026, 19:28.
Wurstblinker
Post07-06-2004, 20:13    Subject: Engine Injectors: Which Motor? Quote
It's a VW part number, not a Bosch one.
I had already checked the online catalog.
Best regards from Kiel.
Sausage blinkers.
faz
Avatar-faz
1994 Audi 80
Post07-06-2004, 21:57    Subject: Engine Injectors: Which Motor? Quote
What kind of funny number code is that?
The 028 130 201 B was used in the B4 TDI engine.
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 22-09-2026, 19:29.
Wurstblinker
Post07-06-2004, 22:00    Subject: Engine Injectors: Which Motor? Quote
Do you know the year of manufacture?
Until 8/92 or later?
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which means 'Sincerely' or 'Best regards' in English.
Translated on 22-09-2026, 19:30.
PrivatBereich
Post08-06-2004, 9:26    Subject: Nozzles: Which Engine Type? Quote
Hi Wurstblinker,
Okay, so if I enter '028 130 201 B' into eCat, I get results. You had a few too many zeros entered above... And 130 bar should probably be 190 bar, at least according to eCat.
Have fun searching.
Private.
EDIT:
AUDI - 80 (8C, B4) - 1.9 TD
09.91-12.94 07.92-07.94 55 75
1896
1896
AUDI - 80 Avant (8C, B4) - 1.9 TD
1896
1896
SEAT - CORDOBA (6K2/C2) - 1.9 TD
02.93-08.96 09.93- 55 75
1896
SEAT - IBIZA II (6K1) - 1.9 TD
03.93 - 08.96 - 55 75
1896
VW - GOLF III (1H1) - 1.9 TD, GTD
11.91-08.97 - 55 75
1896
VW - GOLF III Variant (1H5) - 1.9 TD
07/93 - 04/99 - 02/99 55 75
1896
VW - PASSAT (3A2, 35I) - 1.9 TD
03.91-08.96 10.93- 55 75
1896
VW - Passat Variant (3A5, 35I) - 1.9 TD
03.91-05.97 10.93-03.97 55 75
1896
VW - VENTO (1H2) - 1.9 TD
11.91-09.98 -12.97 55 75
1896
Translated on 22-09-2026, 19:34.
Post08-06-2004, 9:42    Subject: Engine Injectors: Which Motor? Quote
That's exactly what I found yesterday!
SO, ABSOLUT KEIN TDI!
These are injector nozzles for a swirl chamber diesel engine!
Translated on 22-09-2026, 19:38.
faz
Avatar-faz
1994 Audi 80
Post08-06-2004, 21:19    Subject: Engine Injectors: Which Motor? Quote
Already TDi.
What can I do if there's incorrect information in the ECAT?
If you go to a VAG dealer, you can get the injectors for your TDI.
Have you ever heard of "AKTE"?
From 08/92 until the end.
MfG faz
PrivatBereich
Post08-06-2004, 21:32    Subject: Engine Injectors: Which Motor? Quote
Already TDi.
Have you ever heard of 'AKTE'?
Hi Faz!
Natürlich haben wir hier schon mal was von Akte gehört. Und auf deinen Hinweiß hin, habe ich eben extra noch mal nachgeschaut. Die Düse mit der Nummer 028 130 201 B auch für den Audi 80. Allerdings nur für den AAZ und das ist der 75PS TD. Nix TDI icon_exclaim.gif
While the nozzles for the 1Z engine have the same number, they don't have the same suffixes (X, GX, AX, HX, H, G) as requested by Dieselmartin; specifically, they don't have the 'B' suffix.
If you are so insistent on expressing your opinion and claiming an error in the Ecat, then please double-check your statement carefully next time icon_evil.gif.
Private.
Translated on 22-09-2026, 19:40.
Obermeister
Post08-06-2004, 21:41    Subject: Engine Injectors: Which Motor? Quote
The request likely originates from an eBay listing.
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=61372&item=7904166690&rd=1&ssPageName=WDVW
The nozzles shown in the image are not injector nozzles, but rather DI nozzles.
Master craftsman.
Translated on 22-09-2026, 19:41.
Post08-06-2004, 22:22    Subject: Engine Injectors: Which Motor? Quote
Okay, I'm not sure, but either the image or the part number doesn't seem to be correct here.
The fact that the nozzles were purchased for a 1.9L TDI does not necessarily mean that they will fit. icon_lol.gif
According to Ecat, the opening pressure is 150 bar, and it uses a two-spring nozzle holder. Somehow, none of this seems to fit together.
And the part number of the NHG shown in the picture is not even mentioned icon_rolleyes.gif.
The product description is completely useless.
Translated on 22-09-2026, 19:42.
Wurstblinker
Post09-06-2004, 10:39    Subject: Engine Injectors: Which Motor? Quote
It all seems strange to me too!
I contacted the seller again, but I haven't received a response.
Then I'd rather not do that.
Translated on 22-09-2026, 19:43.
faz
Avatar-faz
1994 Audi 80
Post09-06-2004, 18:14    Subject: Engine Injectors: Which Motor? Quote
Shit
@PrivateArea
Sorry, I'm reversing course completely.
I'm really sorry...
MfG faz
PrivatBereich
Post09-06-2004, 21:20    Subject: Engine Injectors: Which Motor? Quote
Sh*t
@PrivateArea
I'm really sorry...
No problem!
Private.
Translated on 22-09-2026, 19:44.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts What are these switches for in the Passat? Transmission, Chassis, Body & Interior
No new posts 0,216 er Düsen mit welchen Einspritzdrück einstellen la... Diesel Engine Technology
No new posts Different nozzles for my engine - what are the effects? Diesel Engine Technology
No new posts Worn nozzles in a Common Rail engine? Diesel Engine Technology
