Severe jerking during full-throttle acceleration in a VW Passat B6 with PD engine, MKN AWX engine code
DirkA6
Post31-05-2004, 20:11    Subject: Severe jerking during full-throttle acceleration in a VW Passat B6 with PD engine, MKN AWX engine code Quote
Hallo!Erstmal muss ich diese super!! Praise the community.
Of course, I had to register right away.
Perhaps someone here can help me so I don't waste too much time troubleshooting.
must spend.
'On my Audi A6 Avant TDI PD 96KW MKN AWX, I'm experiencing the following problem, although it doesn't always occur.'
When I accelerate with full throttle, a harsh jerking occurs at approximately 2600-2700 RPM.
It's like the engine isn't responding to the accelerator. The jerking is only brief, lasting about...
'You can feel a vibration at 200 RPM, after which the engine returns to normal operation. The jerking occurs in every gear, always at the same RPM. Additionally, the jerking also occurs...'
It only happens when I accelerate fully; when I give it normal throttle, the engine runs normally without any jerking.
The jerking doesn't always occur. It's possible that the engine is running normally (up to about 20 km/h).
Then it jerks a few times when you give it full throttle, but then it runs completely normally again.
Turning the engine off and on again has no effect on the jerking/stuttering.
The engine is running normally otherwise. It doesn't smoke, it runs smoothly, and it maintains the RPM.
Idling, it has full power, and it doesn't sound strange.
Tomorrow, I'm going to visit a dealer and have the error codes read.
Perhaps someone here can help me find the cause of the jerking.
Thank you in advance!!
Best regards, Dirk.
Translated on 09-07-2026, 9:17.
DirkA6
Post31-05-2004, 20:36    Subject: Stuttering Quote
Okay, I just tried it again.
The jerking also occurs even when I don't accelerate fully.
When I give it gas while the car is stationary and not in gear, there's no shaking or vibration.
The jerking occurs when the engine is warm.
Best regards, Dirk.
Translated on 09-07-2026, 9:19.
joergs
Post31-05-2004, 22:21    Subject: Severe jerking during full-throttle acceleration in a VW Passat B6 with PD engine, MKN AWX engine code Quote
It could be a sticking valve timing gear or a clogged EGR valve.
dj1
Post01-06-2004, 11:24    Subject: Severe jerking during full-throttle acceleration in a VW Passat B6 with PD engine, MKN AWX engine code Quote
Hey Dirk!
I'm having the same problem.
Have you had the error codes read yet?
You can tell me sometime what it was icon_smile.gif.
DJ1
Translated on 09-07-2026, 9:20.
DirkA6
Post01-06-2004, 13:07    Subject: Error reading Quote
Hello!!
Okay, I just had the error codes read.
!!No errors detected!!
The boss told me to check all the vacuum hoses and blow them out with air. Otherwise, I should replace the mass airflow sensor.
Maybe someone here has another idea.
Best regards, Dirk.
D.
Post01-06-2004, 16:18    Subject: Severe jerking during full-throttle acceleration in a VW Passat B6 with PD engine, MKN AWX engine code Quote
Hello Dirk!
I have the same vehicle. Mine jerks briefly when accelerating quickly, around 2,000 RPM. It doesn't matter if I'm accelerating with full throttle or partial throttle; it doesn't matter if the engine is warm or cold. However, it's been doing this since the very first kilometer.
I've always attributed it to the well-known 'unharmonious' power delivery of the PD.
I'm interested in how your story progresses. I'll continue to follow it.
Best regards, D. (which is actually my name, Dirk).
Translated on 09-07-2026, 9:21.
joergs
Post01-06-2004, 16:43    Subject: Severe jerking during full-throttle acceleration in a VW Passat B6 with PD engine, MKN AWX engine code Quote
Please disable the AGR (agricultural land reserve) feature. That should resolve this short-term issue.
Translated on 09-07-2026, 9:22.
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Engine Noise: Acceleration Problem? Diesel Engine Technology
No new posts Clacking Engine: Volvo V70 & Audi 2.5 AEL Repair Diesel Engine Technology
No new posts 1.9 TDI: Engine Jerking & Troubleshooting Diesel Engine Technology
No new posts Jittering While Deploying: Troubleshooting Guide On-Board Diagnostics (OBD)
