Automatic transmission fluid level
mneu
Post02-06-2004, 17:51    Subject: Automatic transmission fluid level Quote
Where do you check the automatic transmission fluid level on a Volkswagen Golf 4 with a 77 kW engine and a 5-speed Tiptronic transmission? And where do you add more if necessary?
I probably made a mistake icon_cry.gif. I wanted to change the engine oil and grabbed the wrong screw (a 27mm hex bolt, straight down from underneath, the only one that was easily accessible). In any case, what came out wasn't black engine oil, but a reddish-brown, clean oil. I didn't move the vehicle as a precaution.
Please respond quickly; I need the car back soon.
Thank you in advance.
Martin.
Translated on 16-07-2026, 16:10.
PowerSound3L
Post03-06-2004, 7:59    Subject: Automatic transmission fluid level Quote
hi,
In addition, the ATF oil temperature must also be measured using a diagnostic device.
You should have it done by a mechanic.
greetings
Translated on 16-07-2026, 16:11.
mneu
Post03-06-2004, 12:17    Subject: Automatic transmission fluid level Quote
'Thanks, it's been resolved. The mechanic at the gas station showed me the fuel filler opening. I just put everything back in, and that's it. There was a loss of about 5 ml, but that's not significant.'
Translated on 16-07-2026, 16:12.
No new posts Document: Automatic Transmission Leaks 01M Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN: Oil leak at upper internal thread screw, automatic t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Fluid Change 01M Golf III Troubleshooting & Guides
No new posts TDI ASZ: Rising Oil Level - 1.9L Engine Diesel Engine Technology
No new posts Oil Level Rising Slowly Diesel Engine Technology
No new posts Oil level/temperature sensor On-Board Diagnostics (OBD)
No new posts Oil Pressure Light On? Check Oil Level & Sensor Diesel Engine Technology
