Passat: Diagnose Connector Problems & Solutions
Schneemann
Avatar-Schneemann
Post05-06-2004, 9:12    Subject: Passat: Diagnose Connector Problems & Solutions Quote
Good morning, everyone.
I spent a long time searching for the diagnostic connector on my Passat 35i (year 1991) and eventually found it somewhat by chance under the gear stick. Interestingly, in addition to the black and white connector, there's also a blue connector. Does this connector have any purpose or function, or is it just there so it doesn't end up somewhere else? Or what's its purpose?
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 05-08-2026, 9:54.
Uwe@Ross-Tech
Post05-06-2004, 14:31    Subject: Passat: Diagnose Connector Problems & Solutions Quote
The blue stick is for blink codes.
-Uwe-
Translated on 05-08-2026, 9:55.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Passat B7 TDI: VCDS Diagnostics, No Data Blocks On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts OBD2 Connector: Types, Uses & Benefits Diesel Engine Technology
This topic is locked, you cannot edit or reply. ODB Stecker bestellen - wo?? On-Board Diagnostics (OBD)
