Excel Log Alignment: Post Formatting Tips
Klausel
Post27-06-2004, 0:04    Subject: Excel Log Alignment: Post Formatting Tips Quote
Hello!
I need a tip on how to post a VAG-COM data log without losing the column alignment – it should be readable, after all.
"Thank you."
Klaus.
Translated on 13-10-2026, 12:17.
knubbi
Post27-06-2004, 8:35    Subject: Excel Log Alignment: Post Formatting Tips Quote
'...so, I rename the files to *.asc and then import the data into Excel. (In the options, you only need to change the decimal point to a comma).'
Then the data can be perfectly edited.
Unfortunately, Excel can only handle two y-axes. A better option is Origin Pro 7.5 from OriginLab. It can also handle multiple y-axes and is very easy to use.
Knubbi.
Translated on 13-10-2026, 12:18.
Post27-06-2004, 9:55    Subject: Excel Log Alignment: Post Formatting Tips Quote
knubbi wrote:
...so, I rename the files to *.asc and then import the data into Excel. (In the options, you only need to change the decimal point.)
Change decimal commas)
I do it like this:
-> create (and save) a blank Excel sheet (.xls).
-> In the log file, press Ctrl+A and Ctrl+C (to select all and copy).
-> In the empty .xls file, right-click and select "Paste Special -> Values".
Translated on 13-10-2026, 12:19.
No new posts Excel Table: 1993 ECU MWB 0 Data Upload
No new posts LOG from AFN 00575 - This time, Excel with a graph Upload
No new posts Label File 2.6L ABC On-Board Diagnostics (OBD)
No new posts Label File: Definition and Usage On-Board Diagnostics (OBD)
