jannik
01-08-2005, 18:59 Subject: Engine Control Unit Golf IV TDI ALH |
Hello everyone.
I would like to install a new engine control unit (ECU) in my Volkswagen Golf IV.
Volkswagen Golf, manufactured in 1999, with a TDI engine (engine code: ALH).
I've already gotten another one (with the same Bosch and VW part numbers).
I also have VAGCOM.
Could you please provide me with instructions on how to code the engine control unit (ECU) using VCDS?
"Thank you."
Translated on 16-08-2026, 5:39.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
01-08-2005, 20:32 Subject: Engine Control Unit Golf IV TDI ALH |
There's not much to consider, but you will need a VAG-COM device with the unlocked version.
Encoding: 1 represents an automatic transmission, and 2 represents a manual transmission.
To program the immobilizer: Access the combination instrument, read and save adaptation channel 0, turn off the ignition for 15 seconds, and you're done.
Translated on 16-08-2026, 5:40.
Profile PM WWW Garage |
jannik
05-08-2005, 17:16 Subject: Engine Control Unit Golf IV TDI ALH |
I have another question about my engine control unit (ECU).
Okay, I've acquired a used engine control unit (ECU), and now I'm going to install a chip into it.
Coding: 1 indicates an automatic transmission, and 2 indicates a manual transmission.
To pair the immobilizer: Go to the combination instrument, read and save adaptation channel 0, turn off the ignition for 15 seconds, and you're done.
Besides what is described above, are there any other things I need to consider in order to use both engine control units (the original one and the one with the chip)?
I want to be able to swap out the control units.
Thank you.
Translated on 16-08-2026, 5:42.
05-08-2005, 17:25 Subject: Engine Control Unit Golf IV TDI ALH |
No, otherwise there's nothing else to note.
Translated on 16-08-2026, 5:43.
oliverzier Guest
14-06-2010, 10:12 Subject: Engine Control Unit Golf IV TDI ALH |
Hi, I'm also changing the MSG at my place tonight.
Do you need the logic code for the AI?
14-06-2010, 12:17 Subject: Engine Control Unit Golf IV TDI ALH |
oliverzier wrote: | | Do you need the source code for the AI? |
Yes.
Translated on 16-08-2026, 5:44.
Profile PM Garage |
14-06-2010, 13:44 Subject: Engine Control Unit Golf IV TDI ALH |
TDI-GTI-4-Motion wrote: | oliverzier wrote: | | Do you need the logic code for the AI? |
Yes. |
Sure? Not with WFS-II.
14-06-2010, 15:47 Subject: Engine Control Unit Golf IV TDI ALH |
Rainer K. wrote: | | Are you sure? It's not the case with WFS-II. |
It's not the case with IMMO II. I just checked and it's an IMMO III system, but since the car is from 1999, it still has IMMO II installed. Sorry for the mistake.
Translated on 16-08-2026, 5:45.
Profile PM Garage |
