TT Steering Wheel 2006
golf 3 pd tdi
Post09-10-2006, 11:35    Subject: TT Steering Wheel 2006 Quote
Hello, I once saw that the airbag in the steering wheel of the latest Audi TT has two cables connected to the ignition coil. Can anyone tell me what those cables are for? And what's the difference compared to older models? If you were to install this steering wheel in an Audi A4 8E, would you also need to replace the airbag control unit, or would the airbag still work with the old control unit?
 File size:  633.39 KB
 Viewed:  3395 times
Translated on 20-10-2026, 16:55.
Jochen_145
Post09-10-2006, 13:59    Subject: TT Steering Wheel 2006 Quote
Audi now uses two-stage airbags for both the driver and passenger.
This type of igniter requires a separate control signal for each ignition pulse.
Translated on 20-10-2026, 16:56.
golf 3 pd tdi
Post10-10-2006, 10:40    Subject: TT Steering Wheel 2006 Quote
hello,
'So, will the old control unit trigger the new airbag? Or how should I understand this? Because the connectors fit together (A4 8H), but will the airbag deploy in the event of an impact? (I think no one has tried this yet, and I assume it won't work like that).'
Jochen_145
Post11-10-2006, 10:39    Subject: TT Steering Wheel 2006 Quote
I haven't looked at the wiring diagram yet.
However, you will need two separate connection cables for the two separate blasting capsules, which will be controlled separately from the control unit. I cannot tell you exactly how the connector fits, but I suspect that at least one more pin is used.
The old control unit will, at best, ignite one of the two capsules, as the software is only programmed to do so; at worst, it will ignite none icon_cry.gif.
Best regards, Jochen.
P.S. I would advise against attempting any modifications here. At most, try to fit the old airbag into the new steering wheel. If it's not mechanically fully compatible, please abandon your modification idea for safety reasons.
Translated on 20-10-2026, 16:58.
No new posts Lupo Vibration: 6X1 MJ 2002 Doku & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the steering wheel of a 2009 VW Passat B6 with ... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Horn buttons on the steering wheel Transmission, Chassis, Body & Interior
No new posts Steering wheel replacement Transmission, Chassis, Body & Interior
No new posts Steering Wheel Noise: Causes & Solutions Diesel Engine Technology
