| Error code Climatronic 3B, model year 1999, 2000 model | |
| ttns4 |
janosch wrote:
Here is my version of the Climacodes. I would be very grateful for any additions, confirmations, or corrections. Climatronic Passat, Year 1998 Climate Codes Simultaneously pressing [ECON] + [Colder] + [Fan smaller] If (+/-) is present, then the target value can be varied. 00 = Total value, 0=max. cooling, 255 max. heating 01 = Interior Temperature Control Panel (at the Climatronic control panel) 02 = Average solar irradiance index 03 = Solar irradiance index in mW/cm² 04 = Average outdoor temperature, bumper 05 = Outdoor Temperature, Bumper, Current Value 06 = Fresh air intake duct temperature 07 = Air Out Temperature Footwell 08 = Outlet temperature, center 09 = Target Fan Voltage (+/-) 10 = Actual Fan Voltage in 10-1 Volt 11 = Temperature control (0=maximum warm, 255=maximum cold), (+/-) 12 = Center Valve (0=Footwell/Defroster, 255=center), (+/-) 13 = Air intake valve (0=Recirculation, 255=Fresh air), (+/-) 14 = Footwell / Defroster Vent Window (0=Windshield, 255=Footwell), (+/-) 15 = Time since engine start in seconds 16 = Speed in km/h 17 = ? goes to 0, only positive values allowed for climate compressor [ECON] 18 = ? Usually = 0, if very hot, then also cooling fans turn on. Values of approximately 64 to 69 (Correlation?) 19 = Compressor Shutdown Condition, 0=None, 5=Low Speed, 6=ECON, 7=OFF, 11=?, 12=? (when) (accelerate from a standstill), ?=Ambient temperature too low, ?=Temperature Sensors faulty, ?=Coolant, ???=other 20 = ? Control parameters 0 to 100, 100 = max. cooling or heating, decreases towards 0 21 = ? Rule parameters, start at 0, values between -100? and +100 22 = ? Control parameters, if controlled, small values around 0, deviation? 23 = Actual Value Average Outlet Temperature 24 = Target Outlet Temperature (+/-) 25 = Temperature control lever, closed position (warm) 26 = Actual Value Temperature Valve 27 = Temperature control lever, cold position 28 = Central Valve, Impact, Foot/Deflector. 29 = Actual Value Central Valve 30 = Center valve, strike center 31 = Air Vent, Return Air 32 = Actual Value of the Staudruck Valve 33 = Air intake valve, Fresh air 34 = Footwell / Defroster flap stop Defrost. 35 = Actual value of footwell / defroster flap 36 = Footwell / Defroster flap stop 37 = Standby time in minutes, (Ignition off) 0 to 240 minutes. 38 = ? 20 39 = Time since ignition in 4 sec. Tempo 40 = Deviation from the rule, Negative = cool, Positive = heat 41 = ? 0 42 = ? 8 43 = ? 0 44 = ? Usually = 0, but also = 59, Error Memory By simultaneously pressing [Recirculation] and [ECON] (3 sec.). It appears to the left of the 3-digit error code, with the number 00 to the right. Pressing [Temp +] will display the next error code. If the code 000 appears to the left, no further errors are stored. If the [ECON] key is held down for longer than 3 seconds, the memory will be cleared. By pressing [ECON], the normal display appears. 000 = Output complete 30b = Temperature sensor bumper 444 = No errors recorded 511 = Temperature Sensor Footwell 4F9 = Fuse 25 in the fuse box, fan, magnetic coupling Self-diagnosis Ignition is off. Press and hold the [Recirculation] and [ECON] buttons simultaneously, while also turning on the ignition and waiting for 3 seconds. -> The diagnostic test will be performed. -> At the end of the test, the number 02 will appear on the right, and the error code will appear on the left (see fault memory). Hello Forum, Question: Does anyone know about the Climacode 4A6? & den Climacode 4F6? I have deleted the code several times, but it reappeared this morning. I suspect that there might be something to do with a weakness in the power supply or a lack of performance, perhaps a sensor. Who knows more codes? So long Thorsten _________________ Bloos nitt huddle... Translated on 03-07-2026, 14:19. |
| Ratings - Error code Climatronic 3B, model year 1999, 2000 model | |
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.059s
