Coolant Temp Sensor vs. Diesel Temp Sensor for AJM PD
ttns4
Post09-06-2004, 8:15    Subject: Coolant Temp Sensor vs. Diesel Temp Sensor for AJM PD Quote
@Ulf
Didn't you post the part number for a suitable coolant temperature sensor instead of a diesel temperature sensor that is compatible with the PD-AJM engine?
Or am I getting something mixed up?
I can't seem to find anything suitable new_shocked.gif.
Does anyone know the part number, and whether this part can be used as a replacement for the diesel temperature sensor?
I can't find the part number anymore. The FRIENDLY person wanted to order the part.
it neglected to do so.
Thanks for help icon_razz.gif.
Thorsten.
Translated on 16-10-2026, 4:11.
PrivatBereich
Post09-06-2004, 8:28    Subject: Coolant Temp Sensor vs. Diesel Temp Sensor for AJM PD Quote
Here is Ulf's post, which you were looking for. (Search term: '*geber', Author: 'ulf')
I haven't checked whether the part number is included, but the dealer should be able to easily find it if you order a coolant temperature sensor for your car.
Private.
Okay, hier ist die Übersetzung:
'EDIT: Part number included!'
Translated on 16-10-2026, 4:12.
No new posts Color-coded coolant temperature sensor Diesel Engine Technology
No new posts MAP sensor for 1.9 TDI engine with code AHU Diesel Engine Technology
No new posts High Diesel Temp AJM: Causes & Effects Diesel Engine Technology
No new posts TSI instead of TDI Gasoline Engine Technology
