Airback control light is constantly on...
Brushie
Post11-06-2004, 19:10    Subject: Airback control light is constantly on... Quote
Since last week, when the rear lights stopped working and I had to replace the fuse because of it, the Airback lamp in the cockpit is lit.
Here's what actually happened in detail:
I have removed the fuses for the taillights in order to check them.
Then I drove to an auto parts store to get new fuses. This trip was made without the rear lights being secured.
And just on this trip, the aforementioned light then started to shine.
Could this perhaps be related to the missing fuse?
What can I do to make the Airback light turn off again?
As far as I could gather from the manual, the Airback does not function when the light is on.
I am grateful for any tip...
Gremlin
Post11-06-2004, 19:51    Subject: Airback control light is constantly on... Quote
You might also have pulled a faulty fuse...
Error in the airbag system will ALWAYS and PERMANENTLY be reported, even if it occurs intermittently.
-> read error
See you, Gremlin
Ruki
Post12-06-2004, 22:37    Subject: Airback control light is constantly on... Quote
Hi!
I've had that too.
I also accidentally pulled the wrong lever -> turned the light on.
Go to the dealership -> sporadic error fixed -> OK.
Best regards, Ruki
Brushie
Post15-06-2004, 16:34    Subject: Airback control light is constantly on... Quote
@ruki,
thanks for the tip.
Exactly, that's how I did it too.
And to be amazed, they didn't want to pay €1 for it...
No new posts Dashboard warning light for airbag "OFF" is constantly il... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 1.6 constantly shaking/vibrating On-Board Diagnostics (OBD)
No new posts Differential Pressure Sensor: Troubleshooting & Repair Diesel Engine Technology
No new posts TDI in limp mode: Troubleshooting guide Diesel Engine Technology
No new posts Timing Belt Tensioners: Common Failure Causes Diesel Engine Technology
