Which software/cable for Volvo V70?
roorback
Karma: +1 / -2   Thank you, like it!
Post19-06-2004, 14:18    Subject: Which software/cable for Volvo V70? Quote
hello everyone,
I'm looking for a cable or software for my Volvo V70, manufactured in 1999.
If I order a VAGCOM USB interface, can I use it for Volvo as well, especially since I already have a VAG TDI engine in my car?
What can I do with this cable, and what is not possible (blocked)?
Thank you for the information.
Best regards, Uwe.
Translated on 17-07-2026, 16:07.
Uwe@Ross-Tech
Post20-06-2004, 14:14    Subject: Which software/cable for Volvo V70? Quote
Volvo is not part of the VAG group. If the vehicle has a VAG engine, VAG-COM might work with that engine, but nothing else. And even with the engine, I can't guarantee anything, as it's possible that the firmware in the engine control unit has been modified to work with Volvo diagnostic tools and protocols. In your situation, I would suggest finding someone who already has a system set up to test whether it will work at all.
-Uwe-
Translated on 17-07-2026, 16:09.
This topic is locked, you cannot edit or reply. Volvo T5 VCDS? Gasoline Engine Technology
No new posts OBD diagnosis for Volvo V70 On-Board Diagnostics (OBD)
No new posts Fuel Injector Quantity Volvo TDI MSA15.7 Upload
No new posts BLS Label File: Guide & Download On-Board Diagnostics (OBD)
