Does the Passat TDI, MKB 1Z, have an OBD2 interface?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
sven
Post20-06-2004, 15:50    Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? Quote
Does my Passat from the year 1994 with engine code 1Z have an OBD2 interface?
I heard that it doesn't have one. Then I wonder what that connector is to the right of the steering wheel? It even has pins like an OBD2 port.
Translated on 21-07-2026, 8:12.
Post20-06-2004, 18:19    Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? Quote
Yes, 1Z is okay!
Translated on 21-07-2026, 8:13.
WarLord
Post21-06-2004, 19:30    Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? Quote
It's not OBD2.
Best regards, WarLord.
Post21-06-2004, 19:44    Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? Quote
Sure, perhaps we should add that. While the diagnosis is performed via an OBD2 connector (specifically a 2x2 connector), it doesn't support the OBD2 protocol itself.
Uwe@Ross-Tech
Post22-06-2004, 5:36    Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? Quote
It cannot use OBD2 as a protocol.
Okay. But for clarity: VAG-COM uses the VAG protocols anyway, not OBD2.
-Uwe-
Translated on 21-07-2026, 8:14.
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wer hat den OBD2 adapter von elektor ? ==> MFA über OBD2 Diesel Engine Technology
No new posts Diagnosis Interface Diesel Engine Technology
No new posts Interface for controlling the central locking system Electrical Systems, Vehicle Electronics, Multimedia
No new posts VAG-Com and Notebook without a Serial Port Diesel Engine Technology
