Instrument Lighting A3
Holger247
Post24-06-2004, 13:46    Subject: Instrument Lighting A3 Quote
My girlfriend has a 1996 A3, and I recently replaced the original Audi radio with a slightly better CD radio. In the process, I purchased an adapter that allows me to swap the ignition and power connections. Furthermore, there is also a connection for instrument lighting, which I have taken over 1:1.
The lighting on the new radio was quite dim. Since we received the radio for free, we initially thought it might be a problem with the lighting itself, but yesterday I checked it and it was fine (they're LEDs, which rarely break). Then I measured the lighting voltage and was surprised to find that even with the dimmer set to MAX, it only showed around 4V? The Audi is also a bit different in how it's shifted, because there, the speedometer is already illuminated when the ignition is turned on.
Does the Audi have a 4/5V lighting system (or essentially just a control circuit)?
So far, I thought that the instrument lighting was always dim 12V. Or is the dimmer perhaps defective (I don't think so, since the other lighting is very bright.)
GIV - 98 - ALH
Touran 5T 2.0 TDI
No new posts Instrument lighting partially out Transmission, Chassis, Body & Interior
