MichaelM Guest
23-06-2004, 11:22 Subject: Marten Damage: Radiator Hose Repair |
I have a question.
A weasel chewed on a radiator hose.
Does anyone have any ideas on how to prevent this from happening again?
I couldn't find anything useful using the search function.
Michael.
P.S. The car is an A6 C4 1.9 TDI.
Translated on 23-10-2026, 5:05.
mcgyver2k Blaumann
Joined: 04/13/2004 Posts: 77 Karma: +8 / -0 Location: Darmstadt
23-06-2004, 12:06 Subject: Marten Damage: Radiator Hose Repair |
People swear by various methods. Some use ultrasonic devices, while others use a more extreme approach with high-voltage plates that are supposed to repel martens.
Some people have spread dog hair in the engine compartment to deter martens.
I can't say whether it works or not, as I haven't experienced any problems so far.
01er Skoda Fabia Combi ATD
Translated on 23-10-2026, 5:06.
joergs Guest
23-06-2004, 13:15 Subject: Marten Damage: Radiator Hose Repair |
If you had actually used the search function, you would have noticed this.
/viewtopic.php?t=2789&highlight=marten
The title of the thread pretty much says it all.
MichaelM Guest
23-06-2004, 14:11 Subject: Marten Damage: Radiator Hose Repair |
Thank you. However, I hadn't seen the article, and I must admit that I was only searching for information about badger bites. Sorry, I will search more thoroughly next time.
Michael.
Translated on 23-10-2026, 5:07.
Albrecht Profi-Schrauber
Joined: 05/11/2002 Posts: 284 Karma: +10 / -0 Location: DD
23-06-2004, 15:57 Subject: Marten Damage: Radiator Hose Repair |
Hello Michael,
ich habe bei mir um die dünnen Schläuche Plastik-Kabelschutzrohre (vom Elektriker) und um die dickeren (Heizung usw.) dünnen, leicht zu biegenden Maschendraht gewickelt. SeIt's quiet now.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 23-10-2026, 5:08.
Julian Guest
23-06-2004, 16:01 Subject: Marten Damage: Radiator Hose Repair |
As long as the car isn't brand new from the assembly line, a thorough engine cleaning (without wax!) is sufficient.
For those who want to spend money, an electrically charged wire mesh is the only sensible thing to install.
Translated on 27-10-2026, 8:49.
