Steering Wheel Noise: Causes & Solutions
Brösel
Post28-06-2004, 10:38    Subject: Steering Wheel Noise: Causes & Solutions Quote
'When I turn it, I hear a grinding noise. Has anyone else experienced this?'
Translated on 28-09-2026, 10:34.
donalexo
Post28-06-2004, 12:28    Subject: Steering Wheel Noise: Causes & Solutions Quote
Hello Brösel!
I'm simply guessing that the problem is caused by the rotation of the steering column shaft being obstructed by the motor splash shield.
Try the following while the vehicle is stationary: When you turn the steering wheel slightly, listen for any grinding or squeaking noises.
If so, then a simple lubrication application to the rotating joint (radial seal between the steering column and the engine block) will suffice.
The noise you're hearing likely occurred while driving because the steering system tends to slightly oscillate when turning, especially during initial steering input.
This noise only occurred for me when the weather was quite warm.
Good luck with your investigation!
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 28-09-2026, 10:35.
Jan6K
Avatar-Jan6K
Post28-06-2004, 18:23    Subject: Steering Wheel Noise: Causes & Solutions Quote
Alternatively, it could be the contact point of the horn, or the roll/coil/or-whatever-it's-called cable that transmits signals for the airbag, although in that case, it would likely occur in other driving situations as well.
Jan.
1Z5 CFHF / AHB H4D
Translated on 28-09-2026, 10:37.
WarLord
Post28-06-2004, 22:13    Subject: Steering Wheel Noise: Causes & Solutions Quote
Roll/Wickel-or-whatever-you-call-it cable transmission of the airbag.
The part is called a slip ring.
Best regards, WarLord.
Jan6K
Avatar-Jan6K
Post28-06-2004, 22:41    Subject: Steering Wheel Noise: Causes & Solutions Quote
Are you sure?
Because, in my opinion, there's no grinding involved there; that's actually the trick of this winding mechanism – unlike the sliding contact used for the horn.
Jan.
1Z5 CFHF / AHB H4D
Translated on 28-09-2026, 10:38.
No new posts Doku Lupo 6X1 MJ 2002, Vibrationen im Lenkrad Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the steering wheel of a 2009 VW Passat B6 with ... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Horn buttons on the steering wheel Transmission, Chassis, Body & Interior
No new posts TT Lenkrad 2006 Transmission, Chassis, Body & Interior
No new posts Steering wheel replacement Transmission, Chassis, Body & Interior
