Volvo 740 Diesel Pump
Mäffie
Post27-06-2004, 13:32    Subject: Volvo 740 Diesel Pump Quote
Hello everyone.
I'm new to this forum, but I have a rather urgent question.
Yesterday, I replaced the timing belts on a Volvo Diesel 740. While loosening the rear bolt of the camshaft, the wrench slipped, and I slammed it full force into the fuel injection pump. icon_redface.gif
After thinking about it, I reassembled everything. When I started it up for the first time, I was disappointed. Diesel was leaking from the diesel pump at the point where I had previously used the screwdriver. icon_cry.gif It's the shaft where the linkages from the gas pedal connect. icon_question.gif The shaft is also loose, and I can pull it out a bit upwards. icon_idea.gif
Does anyone here know about this? Does anyone know what's broken? And how can I fix it? }
'Or do I have to go to Bosch service? Is it the same engine that's also used in the LT 28? 5'
I think it's called Euro Diesel. It was probably also used in some other vehicles.
Sure, I'll translate the text from German to English. Please provide the text you would like me to translate.
Mäffi.
Translated on 05-10-2026, 23:46.
No new posts T4 Diesel Pump: Replacement & Repair Diesel Engine Technology
No new posts Defective Diesel Pump: What to Do Now? Diesel Engine Technology
No new posts Diesel Pump Springs: Function & Replacement Diesel Engine Technology
No new posts Diesel Pump Diagnosis: Troubleshooting & Repair On-Board Diagnostics (OBD)
