Retrofitting a tachometer
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
BigB
Post19-07-2004, 21:20    Subject: Retrofitting a tachometer Quote
Hey, I did a quick test with VAG-COM today, and guess what, I got a Drehzahl signal. I was so excited, like a little kid. icon_biggrin.gif
Now I know that my Skoda has a sensor. However, I don't have a direct idea of how to extract the RPM signal from the limited connections of the OBD2 connector in a way that would allow me to add an aftermarket tachometer.
Before I get another scolding, I've searched and read, but I haven't found anything that directly helps me, or it failed because of my 'blindness' or my spelling. icon_confused.gif
Okay, so you know what kind of car it is: a Skoda Felicia LX 1.9D, so it has an ABE engine, but it's an SDI. icon_cry.gif
And please, don't make fun of me just because I don't have a turbo; it's annoying enough as it is. icon_cry.gif
Best regards. BigB.
wolfi_b
Post19-07-2004, 21:41    Subject: Retrofitting a tachometer Quote
Hello.
I once retrofitted a tachometer into a friend's Audi 80 from 1984. It was simple: I just replaced the clock with a dashboard instrument (KI) that included a tachometer – and that was it! It might still be that simple today.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Jan6K
Avatar-Jan6K
Post19-07-2004, 22:21    Subject: Retrofitting a tachometer Quote
I would never try to get that signal from the K-bus; it would be a huge undertaking because there's a lot of decoding and other processing that would be required.
You can either find it on some cable, possibly even the connector for the instrument cluster, or you can rig up a small magnet + Hall sensor in a suitable location – the latter is usually easier.
Jan.
1Z5 CFHF / AHB H4D
No new posts Doku Lupo 6X1 MJ 2002, Drehzahlmesser bleibt hängen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lederlenkrad nachrüsten trotz Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Benziner Drehzahlmesser mit tdi stg On-Board Diagnostics (OBD)
No new posts Gasoline tachometer connected to a 1Z TDI engine control ... Diesel Engine Technology
No new posts Drehzahlmesser in Passat 1.6TD von 1992 einbauen Transmission, Chassis, Body & Interior
No new posts Tachometer Installation VW Golf 2: Guide & Tips Diesel Engine Technology
