PLC Communication Problems
sirecki
Post03-07-2004, 2:46    Subject: PLC Communication Problems Quote
I have a KL connector (pre-wired connector), a USB to serial adapter, and VAGCOM 3.112. I can communicate with the engine control unit (ECU), but I cannot synchronize the baud rate for any other ECUs. It's a Ford Galaxy (new model) from 2000. Do I possibly need a connector with a double K-line (KKL)?
Best regards, Sirecki.
Translated on 25-07-2026, 10:27.
Karma: +807 / -0   Thank you, like it!
Post03-07-2004, 9:08    Subject: PLC Communication Problems Quote
No, your car does not use a double K-line.
First, I would check whether it's even possible to access the other control units using VAG-COM, because there's a chance that Ford uses different or software-modified control units here.
Otherwise, I would first get a decent USB diagnostic adapter. With your current additional conversion from USB to RS232 and back, timing problems in the diagnostic protocol are almost guaranteed.
Translated on 25-07-2026, 10:28.
sirecki
Post03-07-2004, 23:42    Subject: USB to Serial Adapter: The Real Culprit? Quote
I tried it today without the adapter, and indeed I was able to communicate with all the available ECUs. It was a bit misleading that the connection to the engine ECU worked, but not to the others.
Thank you for the tip, Rainer.
Translated on 25-07-2026, 10:29.
sirecki
Post06-07-2004, 21:00    Subject: PLC Communication Problems Quote
For your information,
It is the following plug that was purchased from e***:
* Description: INLINE® USB to Serial Adapter Cable, 9-pin.
* Compatible with USB standard V1.1.
* Easiest installation.
* Data transfer rate exceeding 500 kbit/s.
* does not require an interrupt.
USB Type A connector to 9-pin Sub D connector.
* Length approximately 0.2 meters.
* Drivers for Windows 98/ME/2000/XP and Mac OS (8.6, 9.0).
You can adjust quite a few settings when it comes to communication, so I don't want to say for sure that it's definitely the cable, but I just couldn't get it working.
Translated on 25-07-2026, 10:31.
joergs
Post06-07-2004, 21:12    Subject: PLC Communication Problems Quote
Why don't you try using the search function? There's a lot of information about it there.
While I'm not entirely sure what your technical data is trying to tell me right now, I suspect it might be because your USB-to-RS232 adapter isn't compatible with some of the baud rates being used, or that the signal propagation times are increased by the adapter, which prevents VAG-COM from working correctly. However, the threads you find when using the search function explain possible phenomena and their effects in more detail.
Translated on 25-07-2026, 10:33.
No new posts VAGCOM: Communication Problems Diesel Engine Technology
No new posts GRA Communication Issues: Engine & Body Control Units Diesel Engine Technology
This topic is locked, you cannot edit or reply. STG Comfort Issues: Communication Problems Solved On-Board Diagnostics (OBD)
