Tuning Box for Galaxy 1997
nusskuche
Post21-07-2004, 19:58    Subject: Tuning Box for Galaxy 1997 Quote
A friend wants to install a tuning box on his Galaxy 1.9 TDI 90hp, manufactured in 1997.
Now we're talking about the adapter wiring harness. Do we need an 8-pin or a 10-pin one?
I took some pictures of the connector, which we think might be the right one. It has 6 wires going into it, and one hole is empty. So, if it's the correct connector, I would need the 8-pin version.
Nusskuche
 http://www.u68.de/DCP_1458.JPG
 File size:  46.1 KB
 Viewed:  1385 times
 http://www.u68.de/DCP_1456.JPG
 File size:  62.05 KB
 Viewed:  1178 times
Translated on 14-09-2026, 1:22.
joergs
Post21-07-2004, 20:22    Subject: Tuning Box for Galaxy 1997 Quote
That's how it should be! And in the relevant article, you'll also find the justification, in my opinion.
nusskuche
Post21-07-2004, 21:15    Subject: Tuning Box for Galaxy 1997 Quote
Thank you for your quick response. Which article are you referring to?
Nusskuche
I understand icon_redface.gif.
Translated on 14-09-2026, 1:23.
nusskuche
Post24-07-2004, 11:45    Subject: Tuning Box for Galaxy 1997 Quote
Hello Joergs,
I'm unable to remove the control unit located behind the instrument cluster icon_redface.gif.
This gray cable needs to be connected to a pin, but I can't seem to remove the control unit. Is there a trick to it?
I have this power box http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=40184&item=7911669367&rd=1 and a 97 Galaxy.
Sure, I'd be happy to help you.
Nusskuche
joergs
Post24-07-2004, 12:33    Subject: Tuning Box for Galaxy 1997 Quote
'I don't recognize this thing, and I have no idea which cable goes where. I had a similar box in my 1Z, and in that case, this cable went to the gas pedal. If it's the same for you, just connect it to the gas pedal's ground terminal.'
You could have gotten that for cheaper.
Translated on 14-09-2026, 1:24.
nusskuche
Post24-07-2004, 12:58    Subject: Tuning Box for Galaxy 1997 Quote
If you could help me with the engine control unit (ECU) removal icon_biggrin.gif
I can't get the large connector off the control unit because a smaller connector in the back is blocking it. However, I don't know how to remove the smaller connector.
nut cake
Translated on 14-09-2026, 1:25.
No new posts Automatic Transmission Fluid Change 01M Golf III Troubleshooting & Guides
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Airbag sensor issues, 1997 model, type 1H1 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tuning Box for Wendland Vehicles Diesel Engine Technology
No new posts Engine tuning box installation Diesel Engine Technology
No new posts Tuning Box: Save 1L Fuel Per Trip Diesel Engine Technology
No new posts Tuning Box: White Smoke from Full Throttle? Diesel Engine Technology
