Air Pipe Leak Under Turbo Pressure?
Klausel
Post05-08-2004, 22:43    Subject: Air Pipe Leak Under Turbo Pressure? Quote
Hello!
Performance and reliability issues often arise when...
Check the airtightness of the air ducts. This is usually done by visual inspection.
and/or earwax, or (with more effort) soapy water, etc.
used.
Wouldn't it be nice if the average, talented TDI enthusiast...
If a reliable method were available, it would probably cost something.
In the thread by dr_braun.
/viewtopic.php?t=6558&highlight=metalldose*
The speech mentions "extracting" data from the system using metal containers.
He fixed it with the standard quick-release fasteners. Then, it will need...
you can still get a compressor with a pressure gauge - there are air pumps like that, after all.
But how do you solve the valve issue?
Which cans fit (Bonduelle delicate vegetables, Handelmaier's mustard, Nutella)?
I would love to see some specific tips (perhaps summarized in a dedicated article sometime?).
Self-help guides are always worth exploring.
Greetings,
Klaus.
Volkswagen Golf 3, AFN engine.
Translated on 17-08-2026, 8:29.
Georg_G
2012 Volkswagen Golf
Post06-08-2004, 16:42    Subject: Air Pipe Leak Under Turbo Pressure? Quote
Hi there,
Okay, to be honest: You should be able to measure the diameter of the hose that runs from the turbocharger towards the intercooler and find a suitable container for it. I think these hoses are also different on various engines (ASV, 1Z, ASZ, etc.) because they use different turbochargers.
But here's a tip anyway:
Take a plastic bottle of the appropriate diameter and drill a hole in the bottom. Insert a bicycle valve (car valve!) from the inside, with about 1 cm of rubber hose still attached on each side. Glue the entire assembly securely using Pattex adhesive. Then, insert the bottle into the pressurized hose and secure it tightly with a large hose clamp (available at hardware stores).
You can use any pump to pressurize your system. Foot pumps for car tires with a pressure gauge are particularly helpful.
It works wonderfully for me like this.
George.
Translated on 17-08-2026, 8:33.
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tire Sealant: Performance & Leak Prevention Diesel Engine Technology
No new posts Injection pressure, turbo boost for 1.9 TDI PD with chip ... Diesel Engine Technology
No new posts Turbocharger Problems: 1Z Engine Issues On-Board Diagnostics (OBD)
No new posts Mitsubishi L 200 Turbocharger Pressure Problem On-Board Diagnostics (OBD)
