Help, expansion gap seal has fallen into the gap! What now???? Images
Manuel Thomas
Post09-08-2004, 21:07    Subject: Help, expansion gap seal has fallen into the gap! What now???? Images Quote
Today is one of those days when it's best not to get up at all!
First, the Bosch service charges €170 so that I can definitively know that my pump is broken, then I remove a screw from the cylinder head, which I finally manage to remove after 2 hours, while I was trying to refute the diagnosis!
http://img41.exs.cx/img41/2970/PDR_0006.jpg
And then this stupid thermal insulation falls into this gap!
http://img41.exs.cx/img41/535/PDR_0005.jpg
The search for the thermal seal failed! icon_sad.gif Is there any possibility that the thermal insulation ring could fall into the timing belt drive from there, or am I just unnecessarily worried?
Greetings
Manuel
dieter
Karma: +13 / -0   Thank you, like it!
Post10-08-2004, 9:50    Subject: Help, expansion gap seal has fallen into the gap! What now???? Images Quote
I've experienced this myself.
The sheet is not closed for the belt drive, so your only option is to remove the sealing ring. I removed the upper ZR cover and used a wire to poke around in the gap. It was a struggle, but eventually I got it out.
Good luck,
Dieter
T3 syncro 16 AFN
Manuel Thomas
Post10-08-2004, 18:30    Subject: Help, expansion gap seal has fallen into the gap! What now???? Images Quote
I have already done that. I have pushed wire into every visible corner and through every opening I could find. The poetry seems to be gone??????????
I've already driven 40km today without any problems. I think I might have lost you along the way. If the engine is still cold, I will remove the timing belt cover again and check.
Otherwise, I would have to remove the timing belt and the gears in order to get the separating plate out.
Greetings
Manuel
No new posts Oil Pressure Zero on 1Z TDI: Causes & Fixes Diesel Engine Technology
No new posts Car Fell Off Jack: Embarrassing Moment Transmission, Chassis, Body & Interior
No new posts BKD Images Upload
No new posts DPF Images: Old vs. New, T4, ACV Upload
