Turbo Problems: Low Boost on Tuned Audi 1.8T?
wolfi_b
Post27-07-2004, 9:29    Subject: Turbo Problems: Low Boost on Tuned Audi 1.8T? Quote
Hello!
My 1Z engine, according to my tuning company, has 110 horsepower. However, it produces some smoke at all engine speeds under full load, and quite a lot at high RPMs. The tuner mentioned beforehand that this was to be expected with this engine. I somehow feel that the boost pressure is too low. I have an adapter and VAGCOM, but unfortunately, I don't have a laptop that my finicky 1Z of the first generation will work with. Besides, only group 0 can be read, and that's at a measly 0.4 measurement values per second.
According to a technical article with specified values, the standard 1Z engine has a turbocharger boost pressure of 0.85 bar. In my opinion, the turbocharger boost pressure should now be at the AFN level, which, according to the article, is 0.95 bar.
Am I right in my assumption?
2. Question:
According to my tuner, the second generation of the 1Z engine can be tuned to produce 116 horsepower.
Differences in the engines: different turbocharger, mass airflow sensor instead of volume airflow sensor, ESP with a different sensor for fuel injection quantity.
But what causes the difference? Is it the turbocharger? Does that mean mine is already operating at its limit, and is that why the engine is producing excessive soot?
I'm looking forward to your answers.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 29-09-2026, 0:46.
No new posts P0401 Error: Low EGR Flow - Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi, up to 2:00 AM, insufficient heating power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0420 - Catalytic converter system, Bank 1, efficiency to... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low boost pressure below 2500 RPM, Passat 2.0 TDI BMP Diesel Engine Technology
No new posts Asche und Russ bei DPF-Regeneration Diesel Engine Technology
No new posts TDI PD Engine: Power or Just Noise? Diesel Engine Technology
No new posts 3.0 TDI (BMK) - lots of smoke, little power Diesel Engine Technology
